Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Continually getting paper jams. Not picking up the paper. probably needs cleaning and maintenace. Bought at staples a couple of years ago. Where can I get service. Model is Intellifax 4750
  • 168 Answers
Have you tried to clean the feed rollers yourself?
I would try cleaning the feed rollers before bringing it in for service.
You can slide the paper drawer completely out, and then look under the machine to find the feed rollers.
Usually they are Gray.
There is a chemical that you can buy at your local hardware store called "Goo Gone". This is a cleaning chemical that will clean the rollers and not dry out the rollers like alcohol would.
I hope this helps.
Good luck.
Mac =)
Feel free to ask more questions if you have any.
Posted on Mar 22, 2008
SOURCE:
Paper jams after pulled in skew
Mine did this ages ago. I found a staple had accidentally fallen into the printer and jammed on one side causing the paper to go in skewed and then jam up. Get a torch and have a really close look inside where the rollers are for staples, paper clips or bits of paper stuck on the rollers.
Aug 28, 2015 | Canon Pixma MP250 All-in-One Color InkJet...
OKI C9600 paper jam problems: Paper jams continually, either on first attempt to printing or if it prints a page the 2nd page inevitably jams. Printer has only done 1500 pages since new ,and i have removed...
Wow! That's quite the printer you have there. The C9600 does have a feed roller in the front; and it's not uncommon for paper to still get stuck. Does your paper "fan" when it goes through; or simply, go through and jam? It's possible a paper feed sensor is bad too. Another thing you might want to check is the paper tray; and that the paper is set to the proper size.
Also be aware, the OKI 9600 had a recall a year or so ago for some potential "shock issues" I would advise you to check with OKI directly to determine if this printer is part of that issue too.
Jan 04, 2011 | Office Equipment & Supplies
HP PSC 500 makes loud noise and says paper jam, but theres no paper jam!!!!
The carrier shaft is probably dry. Use sewing machine oil or 3 in 1 oil and put a couple drops on either side of the carrier, move is back and forth a couple times then power on. While in there, clean the pick roller with a damp cloth and rub the rollers horizontally
Nov 25, 2010 | HP PSC 500 All-In-One Printer
My HP4100 DTN is continually having paper jams for no obvious reason. What can I do to resolve this? (I mean, I know how to resolve the jams, but how can I make sure it does not jam all the time)
Old age printer, prepare to replace the parts.
Step 1: Clean all paper path sensor, replace paper pick up rollers, seperation pads, check with out duplexer unit..
Step 2: Even paper jamming replace fuser assembly..
Step 3: Check with duplexer unit, clean deolexer sensors & rollers..
Nov 23, 2010 | HP LaserJet 4100dtn Printer
Work Center Pro 575 always gets paper jams
If a document jam occurs during a transmission, the message "DOCUMENT JAM" is displayed. If this occurs, follow the procedure below. It is recommended that a duplicate from a copier, of the jammed document be used to reduce the chance of a jam when resending the document.
See Chapter 3, "Loading Documents" for document specifications and recommendations which may help avoid paper jams.
Note: The power can be left ON when clearing a paper jam.
Typical Causes of Document Jams
Recommended Procedure
The document is fed at an angle.
Adjust the Document Guides to the edges of the
document.
The document paper is too thin or too thick.
Make a duplicate using a copier and use the copy
as the sending document.
Document has tape or pieces of paper taped to it.
Remove the tape or make a duplicate using a copier and use the copy as the sending document.
The Control Panel Cover is not fully closed.
Close the Control Panel Cover fully.
The document is stapled. Remove the staple(s), or make a duplicate using a copier and use the copy as the sending document.
Basic Troubleshooting
1. Remove all documents from the Document Support.
2. Open the Control Panel Cover.
3. Remove the document jam. Remove any pieces of paper, paper clips, or staples that may have caused the jam.
4. Close the Control Panel Cover.
5. Verify the display has returned to the Standby Mode.
Jul 13, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
EPSON SX20O RECENTLY BOUGHT ,GIVING ME A PROBLEM WITH PAPER JAM . IT PRINTS THREE PAGES THEN START TEARING PAPERS CAN YOU HELP THANKS
You may wish to switch paper types.....head down to Staples or Office Depot (or where ever) and pick up a small package of "jam free" paper....it usually states that it is 99.98% jam free... If that doesn't fix the problem, I would suggest returning the item. Best of luck!
Nov 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Fax machine says Rec. Paper Jam
Check the paper, is it loaded correctly? Have you fanned the paper to break the production bond? Is the paper a good quality? Remove all of the paper and check inside for any foreign objects.(paper clips, staples) Reinstall paper. Mark the top sheet of paper with an x, press the copy button, does it even try to pull in the paper?
If yes, the pick up rollers are likely dirty, and need to be cleaned, remove the paper and clean the rollers with some isopropal alcohol, and a soft cloth. (available at a drug store) Retry
If it doesn't try at all, then turn machine off and unplug it for a few minutes,re connect, power up. Any change? if not machine has a feed problem that may require a Tech to look at.
Hope this is of some help.
Ed
Apr 20, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
PAPER JAM
The problem sounds like your rollers have lost their grip. Remove the paper tray and tip the printer up. Push the red lever on the left of the printer down and you will see the feed mechanism with two wheels. Remove the rubbers on the wheels and turn them inside out. Replace them on the wheels with the worn side now inside and the 'sticky" side out. You should get at least another couple of years worth of use before you need to replace them.
Aug 22, 2008 | Lexmark E232 Laser Printer
Paper jam- now prints with lines
Paper jams are often caused by bits of paper left in the printer. If you can't get to it by opening any access panels, then the printer may need to be disassembled. Check all your access panels first. If that doesn't do anything, visit Staples or an Office Supply Store like that, and purchase a pack of Printer Cleaning Paper. The one I have, the paper is sorta folded like an accordian, and you get some spray to spray the paper. Run that thru the printer according to instructions a couple times. Are you able to remove your printhead? Check that for buildups. Lastly, how long have you had it? Canon printers offer a one year warranty. Good Luck!
Nov 17, 2007 | OEM Systems PIXMA iP3300 Photo Printer
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
228 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
