Question about Car Audio & Video
Removing speaker from door in 2003 Dodge Durango
I need help in getting the inside door panels off in order to remove a damaged speaker.
I removed the two screws in the lower panel, but it will not budge! I cannot see any other screws but the panel is being held in place. Do I need to go to a dealer or car audio shop to get the speakers replaced?
I have a cadilac cts and im trying to remove the subwoofer in the back
Posted on Mar 19, 2009
    Champion:
  • 217 Answers
The panel is held down by screws and plastic clips. Make sure the arm rest/handle doesn't have any screws in it either. The plastic clips will pop out with enough force. (This is how all of my cars doors were designed.)
Posted on Mar 21, 2008
How do I remove the rear wiper assembly from a Dodge Durango 2003?
Most Chryslers from this year band require removal of the rear door's liner to access the motor. The motor is held on by two or three compression nuts with bolts that pass through the motor housing/frame. NAPA has new ones or you can use simple nuts and use both metal and rubber bushings to prevent possible rattling noise after mounting a new motor. A car or your year it is best to go to a recycle yard and get the whole assembly for cheap so you don't need to disconnect the motor from the wiper arm linkages. It's not difficult. The wiper must be removed from the back of the car and the large screw underneath the rubber gasket removed as well. The rest of the removal/install process is done from inside the rear door, once the rear door panel is removed.
Apr 03, 2015 | 2003 Dodge Durango
Passenger power window wont go up on 2003 dodge durango
You really need factory wiring diagrams to start
You have to at least access the window switches
& check them, before removing the door panels, to
check the motor or regulator
Jun 23, 2012 | 2003 Dodge Durango
Need to find window assembly schematics for 2003 Dodge Durango
  • Are you wanting like a wiring schematic?
  • Let me know if you need anything additional.
  • Thank you for using FixYa.
Regards, Tony
Jul 23, 2011 | 2003 Dodge Durango
Rear door on left drivers window drop in track cable is the cable just of or should i replace motor 2003 dodge durango
you will have to remove door panel and check. most likely the cable broke and you will need to replace motor mechanism
Apr 18, 2011 | 2003 Dodge Durango
How to remove rear door panel on 2003 Jeep
I am assuming you are asking about the 2003 Jeep Cherokee, these are the instructions for the Cherokee, if not, please repost your question specifying which Jeep you have.
Remove all screws securing the interior door panel on. There is a screw on the top portion, and two in the handle.
  • 2 Gently pull on the interior door panel to release the plastic clips that fasten the panel. Use caution to avoid damaging the plastic clips.
  • 3 With the door panel loose, release the two wire connections to the window- and door-lock switches. You must also remove the lock-mechanism poles.
  • 4 Remove the four screws holding on the speaker. Remove the wire connector and set the speaker aside.
  • 5 Remove the window seal by gently pulling. Make note of how each wiring harness is fed through the door panel.
  • 6 There are two clips that secure the window to the track. Using needle-nose pliers, gently pull the clips off of the window. Carefully lift the window out of the track and set it aside.
  • 7 Remove the motor from the track system by removing the three bolts holding the motor to the track. Remove the unit from the door and place it on a flat surface.
  • 8 Remove the lower cable guide by pressing on the tab with a screwdriver and releasing the guide assembly. You must also remove the window-guide mechanism. Make sure it is turned so that you can connect the cable in the guide.
  • 9 Install the replacement window motor and guide assembly onto the door panel using the three bolts. Make sure the cables are aligned properly before reinstalling the window in the vehicle.
  • 10 Install all peices in the reverse order.
  • Read more: How to Replace the Window Motor on a 2003 Jeep Grand Cherokee | eHow.com http://www.ehow.com/how_6534717_replace-2003-jeep-grand-cherokee.html#ixzz0xNocSDED
  • Read more: How to Replace the Window Motor on a 2003 Jeep Grand Cherokee | eHow.com http://www.ehow.com/how_6534717_replace-2003-jeep-grand-cherokee.html#ixzz0xNosJL4f
  • Read more: How to Replace the Window Motor on a 2003 Jeep Grand Cherokee | eHow.com http://www.ehow.com/how_6534717_replace-2003-jeep-grand-cherokee.html#ixzz0xNp4YDQ0
    Aug 23, 2010 | Audio Players & Recorders
    Removing rear door panel
    On the inside trim, you can remove screws (these screws may be covered by filler pieces or may be visible, or they may require you pry a plastic piece off that covers the screws) that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls.
    Jun 24, 2010 | 2003 Dodge Neon
    How to remove the inside door panel from a dodge 2005 2500 pick up
    FRONT DOOR TRIM PANEL - REMOVAL
    Release door latch and open door.
    Roll window down.
    Remove window crank Window Crank - Typical , if equipped.
    Remove screws attaching trim panel to door Door Trim Panel and Trim Panel Screw
    CAUTION: Do not forcibly pull trim panel from door, damage to trim panel may occur.
    Simultaneously lift upward and outward to release retainer steps from inner door panel Trim Panel Retainer
    Disengage inside handle linkage rod from inside handle.
    Disconnect speaker harness wire connector Speaker And Power Mirror Connector
    Disengage power mirror wire connector, if equipped (driver's side only) Speaker And Power Mirror Connector
    Disengage clips attaching power window/lock switch panel to door trim panel. Disengage wire connector from switch panel, if equipped Power Door Lock/Window Connector
    Separate door trim panel from vehicle.
    INSTALLATION
    Position trim panel at door.
    Engage wire connector for window/lock switch panel, if equipped. Engage clips attaching power window/lock switch panel to door trim panel.
    Engage power mirror wire connector, if equipped.
    Connect speaker harness wire connector.
    Engage inside handle linkage rod to inside handle.
    Align trim panel retainer steps with inner door panel and slide trim panel into place.
    Install screws attaching trim panel to door.
    Install window crank, if equipped.
    Hope helped with this; remember rated this help. Good luck.
    Nov 12, 2009 | 2005 Dodge Ram 2500 Truck
    2003 Dodge Durango - How do I take off door panel
    After you have removed the screws (one behind the door handle, you will see a little tab, pull it back to expose the screw) lift the panel and look behind it, there you will see (2) rods going to the door handle and lock. Use a small screw driver to pry the keepers away very gently. Pull the rods away from the keepers. Also, you may want to remove the panels from the arm rest and disconnect the wires from the control panel. I just replaced the window regulator for the second time.
    Jun 11, 2009 | 2003 Dodge Durango
    Need to replace driver side mirror on 2005 Durango Limited Editio
    On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
    Jan 22, 2009 | 2005 Dodge Durango
    Door removal
    there will be a torx head screw somewhere around not the door handle but the handle on the door, and then a phillips head screw above the mirror adjuster and 2 more screws on the bottom of the door. once all of those are removed, simply pull upwards on the panel until all clips break loose. Be careful not to break the harness, of the door handle and electric locks and window. once the panel is pulled back the speakers should be exposed. hope this helps.
    Nov 21, 2008 | 2002 Dodge Durango
    Car Audio & Video Logo
    240 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
