Question about Thermador Freezer FREEDOM® T24ID80PLS
Thermadore Freezer Why will the controls to the ice maker/water dispensers on my door work
  • upsettoo Oct 22, 2008
    Thermador has replaced my ice unit 3 times and it still doesn't work! Customer service is of no help-
I assume you mean do not work? I have the freedom 18" with through the door ice water. Themador has replaced the whole unit already. The second stoped woking after six weeks, call is in to repair again......
Posted on May 03, 2008
The ice maker makes a loud racket unless the freezer door is open.
You have an object jammed in ice makers path. The freezer door has something on it that is pushing into the ice maker perhaps.
Feb 08, 2013 | Samsung RS261MDBP Side by Side...
I own a Thermador Freedom Collection 18 inch Built-in Freezer Column with Exterior Ice and Water Dispenser Model T18ID80NRP and have had this unit for approx. 2 years as a companion unit to my Thermador...
No solution but just a warning. We had this same thing happen. They sent a repairman to replace the control board. Then did it again. Just before Christmas, the WATER started dispensing by itself. Luckily, I was nearby and heard it or the damage would have been extensive from flooding. They are now 'working on' getting a response from Thermador. I feel like this thing is just a homeowners claim waiting to happen.
Oct 28, 2010 | Thermador Freezer FREEDOM® T24ID80PLS
Ice Maker is dead on Kenmore Elite TRIO bottom freezer with French doors. This model has separate water dispenser inside fridge on left and ice maker in bottom freezer. We've tried replacing the filter,...
you can check the fill tube in the freezer make sure it is not blocked with frozen water. if you can disconnec the water supply line from the fill tube try and reset the ice maker to advance it to a new cycle and if water come out of the supply line the you knwo there is a blockage if no water comes out the the ice maker may be bad or the fill valve is bad. last thing you may need to call a service tech out to find the problem.good luck i hope that this has helped some what.i would like to knwo how thing go for you
Jan 22, 2010 | Freezers
Our BEKO AP930 fridge freezer ice maker stopped working and we replaced the ice sensor but now the water dispenser isn't working. pipes connected correctly and there is a water suppky, Any ideas??
i had a similar problem with mine and the advice i got(possibly on here) was to leave the freezer door open to let the water supply pipe in the door defrost,put some blankets/ towels in the freezer to stop the
food defrosting,it worked for me and only took about 10 mins.
Dec 30, 2009 | Freezers
Ice maker icing up
Sounds like you may have a couple of problems here. The frost build up could be from a bad door seal. Moist air can be drawn in and collect on the inside. As for the water temp, it sounds like the water line connected to the refrigerator could be tapped off a hot water line. It needs to be connected to a potible cold water line.
Aug 26, 2009 | Kenmore Freezers
Frigidaire won't make ice & dispenses only about 4 oz. cold water
Water frozen in the freezer supply line - you need to thaw out the freezer. About six hours, door open, turn freezer OFF. You'll need a cooler with dry ice for your frozen food. 99% certain it'll work after that.
May 26, 2009 | Freezers
No water to ice maker or water dispenser
You're funny. This is a portable 12/120 volt model. It dosn't have a water dispenser or ice maker :-)
Dec 27, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Freezer is not making ice
PULL THE FRONT COVER OFF OF THE ICE MAKER AND CHECK THE PLASTIC GEAR ON THE FRONT OF THE CONTROL. THE CENTER OF THE GEAR HAS TWO PLASTIC TABS THAT HOLD THE GEAR IN PLACE. IF ONE OF THE TABS IS BROKEN OR MISSING, THE CONTROL OR THE WHOLE ICE MAKER NEED TO BE REPLACED.
CHECK THE ICEMAKER TO SEE IF THERE IS WATER OR ICE IN THE MOULD. IF NO WATER OR ICE, THE FILL TUBE IN THE BACK WALL MAY BE FROZEN OFF. REMOVE THE FILL TUBE AND CLEAR IT OF ANY OBSTRUCTION. YOU CAN ALSO USE A HAIR DRYER TO MELT OUT ANY ICE FROM THE FILL TUBE. THE OTHER POSSIBLITY IS A BAD WATER VALVE. THE WATER VALVE HAS TWO OUTPUTS, ONE FOR THE DISPENSER AND ANOTHER FOR THE ICE MAKER.
Mar 31, 2008 | Freezers
Thermador Freezer FREEDOM® T24ID80PLS Logo
302 people viewed this question
Top Thermador Freezers Experts
John Tripp
John Tripp
marlin siecinski
Roderick Scott
Roderick Scott
Are you a Thermador Freezer Expert? Answer questions, earn points and help others
