Question about Orion STV2763 27" TV
No uhf with antannae
Had sattelite. Now trying to use antannae. Can not get channels above 12.
What is required to get uhf channels?
Thanks.
Joel
joelwilson@fuse.net
    Novelist:
    Champion:
  • 236 Answers
UHF channels are basically "line of sight" type signals. You need to be pretty near those UHF stations.
You need a Uhf or combination Uhf/ Vhf antenna to receive them - - Usually an out-door type.
Your TV needs to be set in the "antenna" mode to tune beyond channel 13 "air type" channels. Channel 14 is the first UHF channel if you're in the antenna mode. If you're in the "Cable" mode then channel 14 is a cable channel which is operating at a different frequency from UHF.
I hope this will help you!
Stargazer
Posted on Apr 06, 2008
Renco remote how to reset tv channels
On your Renco Cable Controller Remote Controller, Press on/off switch to off then press -/--/--- Button for about 12 times then press 2 to restore all UHF channels. Press off again then 0 for about 12 times then 2 to restore all VHF channels.
Jul 13, 2014 | Televison & Video
Renco tv cable converter channel loc how to remove
1) On your Renco Cable Controller Remote Controller, Press on/off switch to off then press -/--/--- Button for about 12 times then press 2 to restore all UHF channels.
2) Press off again then 0 for about 12 times then 2 to restore all VHF channels. This will also remove the Lock of channels.
Nov 17, 2013 | Televison & Video
I have a sony EX4|40 with built in Freeview. However, the port on the tv is a UHF (?) port (Im not technically minded, my port names may be wrong so I hope you know what I mean), The cable which runs from...
xtreamz_69,
It sounds like you connected the coax cable to your TV. What channel is the TV set on when you have the Freeview connected? Because you are using a coax cable, the TV should be set to either channel 3 or 4 (normally channel 3). Check to make sure your TV is on one of those channels. Also verify your receiver is on. Your TV has the several other type ports (HDMI, component, composite) as alternatives to pick up your picture. If you have any other questions, please post to this site.
Ray Calo
DISH Network
Jan 19, 2011 | DISH Network IR Remote Control
How do i set the 2632 from cable to uhf/vhf antanna
Have a good antana like a roof or a HD antana plug into the ANT tv hole.Tv remote push the tv menu.Goto SETUP go down to CH.push and pick AIR not cable.Push for scan for free DTV tv channels.When finish scan u will have all the free DTV channels,depend how good is ur tv antana receptions is.
Nov 26, 2010 | Polaroid FLM-2632 Television
I believe the car radio is a Sony Xplod. I have sattelite radio as well. I don't know what button my nephew hit, but now I can't access sattelite radio. When I hit mode- it goes from Radio to CD to MD...
The "Changer Controls" are typically used for the XM controls. I would try turning off the unit and the car and pulling the Sony radio's 'memory' fuse for 10 minutes then restart. This is a tricky one.
Aug 12, 2010 | Sony Car Audio & Video
I can't get all the antenna channels
I do not know if your in the USA or a international country or what have you. But part of the reason why older tv's still get a RF signal is because of there older tuner inside. Now I know the USA went digital last year and in saying that this could be you problem but lets not put the horse in frount of the wagon here. You might want a try a better antenna first to see if the inporves things. But most tv's use UHF/VHF/IRC/HRC and the older ones just use UHF/VHF and only can pick up channnels with those tech. But your newer ones block out low frequencies UHF/VHF is its harder to get a signal. I would say try a better antenna or you might bne in a digtial area where you need a little converter box.
Thanks
please be considerate and rate with the thumbs to your top right before you close the window, alos if you will leave me some feedback.
Apr 13, 2010 | Samsung HP-S4253 Television
VHF channels come in however UHF channels are not
uhf and vhf tuning is performed in one board(tuner brd) there are some on line part stores that can help you with the number and price, you'll need to provide the model number. partstore.com is one of them, but there are more.good luck.
Jan 09, 2010 | Vizio GV46L 46 in. LCD Television
No uhf channels
Go into your tv menu. Find the area that you program the channels. Switch the type of signal from "cable" to "anntena" and then use autoprogram to reprogram the tv.
Sep 13, 2008 | Durabrand DWT2704 TV
DTA800 do not receive UHF
I am not from that part of the country, so I can't say for sure, but check the following:
1) Are the UHF channels local and small stations? If so and under a certain power level, they are not required to broadcast in digital. THere may not be digital UHF channels local to you.
2) The changeover is required by law to occur by Feb 2009. Not all stations have made the change yet. You could still be in an area where the stations have not yet converted to digital broadcasts.
Make a few calls to find out which category yuo fall under above. If you don't fall into either of the above, update this and we'll look elsewhere for the problem.
Dan
Jun 16, 2008 | RCA Audio Players & Recorders
RCA VCR VMT 385A support needed
c is cable
h is hi vhf (7-12)
l is lo vhf (2-6)
u is uhf (13 and up)
Dec 31, 2007 | Televison & Video
Orion STV2763 27" TV Logo
209 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
