Your drive belt could be coming off for many reasons oil on the pully making it slip off,or it could just be worn out and strecht out but the main reason could be is your belt is to loose and this could mean either you motor is loose and moved back or you rear end is loose and move up or even both. I am no pro so I am just going by experiance so my suggestion to you look under your mower and see if you belt is loose and also look and see how worn it is and if it is some pros will give free advise right over the phone of what you should check or they can tell you the exact problem.
