SOURCE: Ipod nano lock forgot password
First, try to restore using iTunes. If this doesn't work, place your iPod in disk mode (hold the menu and center buttons down togther) and as soon as you see the Apple symbol come up hold the center and play (bottom) buttons down together until you see a check mark (disk mode). It may take a few trys.
Now connect your iPod to your computer. Go to my computer and right click the drive associate with your iPod (for example F: ) and scroll down to FORMAT. THIS IS VERY IMPORTANT - CHOOSE FAT32 and then check the "Quick Format" box. After you do this then use iTunes to Restore your iPods another time.
SOURCE: I have accidentally locked my ipod nano Version
My brother did the same thing on his.
Hold in both the center button and the play button for a few seconds until a white apple appears.
This will not reset your music.
When it reappears you should be good to go.
If it worked out good, please give me a good rating. Thanks!
SOURCE: Apple ipod nano 4GB silver
Hi tomasi cava...
If you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
Please take time to rate me thumbs up.
somebody put a lock on my ipod and i dont know my code so i have to reset it and i dont know how to do that.
forgot password to my ipod nano
forgot my screen lock code and i cant get in
i was playing with my i pod and i accidentally locked it help
