Question about SanDisk Sansa e250 MP3 Player
Sanso 250 First the dial was lit up and everything else did not work. Held down the power button and now it says key locked system shutdown. Now what? Never had a problem before.
    Problem Solver:
I am not sure, but is it on lock?  when it is on lock and you turn the player on, it will say key locked system shutdown and then shut off. that might be the problem. hope it helps
Posted on Mar 25, 2008
SOURCE:
Mid tablet wont shut down
So you need to be In the main menu interface then press the power button for about 5 seconds to shut it down. Below is the power section out of the manual.
1.2 POWER
startup: Long Press and hold the power button, the system will enter the main interface
shutdown: In the main menu interface, Press the power button about 5 second to shutdown, The system can hint "power off" option, Clike"ok". you can safely shut down.
Lock screen: Short press Power button to lock screen or unlock screen.
Remark 1.When power is empty,system will shut down automatically.
2.Illegal turn off the device,restart will scan and restore the disk,it may take longer time to enter into system
Jan 30, 2013 | mid Archos M729B Android Tablet
HP pavilion ze4300 will not shut off.
Two things you can do, you can hold down the power button, keeping it held down, should power it off. The other solution is to remove the battery, this should cause the Notebook to power down
Feb 28, 2011 | HP Pavilion ze4300 Notebook
Avaya Partner line always lit
If the line button is lit then something within the system has picked it up. If the phone is a multiline set, the line 1 light on the set that is using the line will show green. The line could also be held by either a cordless phone on the system or the voicemail system. The easiest way to clear the line (if the held set isn't apparent) would be to cycle down the power to the phone system for a moment. That will clear the line if its held by the voicemail
Jun 02, 2010 | Avaya Corded Phone avaparp18d
Caps lock key not working - held down the key for
Press shift key for at least five times and then release when you hear a peep sound, On the Keyboard tab, uncheck everything and click Ok, if this doesn't solve, then again press five times and uncheck everything and click Ok. I also like to know if you were typing on some program like Ms-Word when the problem occurred. is the caps lock led on? Please let me know so that I can help you better.
May 06, 2010 | Microsoft Windows XP Home Edition Service...
Model RT2500/ RT 2500R. Standby button is lit but when I press it the home theater fails to turn on
I had the same problem. I held down the power button while plugging the unit into the wall and it fired right up. works fine now. You might have to do this a couple of times but mine was fixed on the first try.
My model is the RT2500
Sep 01, 2009 | RCA RT2500 System
After shutdown of gateway laptop blue power button stays lit.....
Hi this sounds like your computer is in hibernation mode as opposed to shut down mode. Could you check and see as if running Vista many people assume that clicking on the brown power type selection under start that they are shutting down where as this actually only hibernation mode and clicking on the little arrow to the right of this and selecting shutdown is the way to go.
I hope this helps
Apr 07, 2009 | Gateway MX6441 Notebook
HP dv6835tx Notebook with Visa Ultimate 64-bit will not shut down
From what you've described, it sounds like you are clicking the Standby button, instead of the actual shutdown option. On the Start button, you will see (from left to right); Left: Start Search Middle: Standby Middle: Lock Right: Arrow Clicking the arrow will show you the Shutdown menu option; http://blogs.chron.com/techblog/archives/shutdown.jpg
May 26, 2008 | Computers & Internet
Key LOCKED-System shutdown
you void the warranty of the player by doing that. What i suggest you do is you can let your player dry off until all the water inside it disappears.
Aug 29, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
129 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
