Question about Lands Phones
The phone will not ring for incoming call and neither will the answering machine pick up. We can make outgoing call with no trouble and can take an incoming call whenanother phone lets us know that a call is incomeing. The phone is less than two months old. It is a model EXA15680.
  • Anonymous Apr 13, 2008
    Phone will not ring in the house. Machine will not pick up the call after the usual 4 rings. The caller hears the ringing. Ony way I knew I had a call was because the TV displayed the caller's name and Phone #.
Problemas con telefono uniden no conecta la linra telefonica
Posted on Oct 29, 2008
Vtech answering machine will not pick up properly
could be outgoing message is set to announce only without an anounce only message being recorded. see http://pdfstream.manualsonline.com/8/8c8ae66b-b461-40cb-b213-039e3c56ab64.pdf page 28
May 02, 2014 | Vtech ia5874 Cordless Phone
MY X5650 WILL SEND FAXES BUT NOT RECIEVE THEM
Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Dec 16, 2011 | Lexmark X5650 All-in-One InkJet Printer
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Lexmark pinnacle pro901 will not receive faxes i can send but can not receive what do I do
Are you sharing your home phone line with your fax? Do you have an answering machine or a voicemail feature in the same line?
If you have a voicemail feature in the same line as the fax, you may want to subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Nov 02, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Fax is not coming through.
Jul 06, 2011 | Lexmark X6150 All-In-One InkJet Printer
We can not receive incoming faxes. The phone ring once and then clicks off. We can use the phone. We can fax outgoing. How can we receive incoming faxes?
The problem may be in your phone line.
Try another phone in place of the fax machine and call in. You may find another phone does the same thing. It's possible there is a high-resistance short on the line. At low voltages during outgoing calls this won't affect anything (or it might occasionally cause some noise). But when your phone rings there is around 100 volts present. When the phone starts to ring, the short causes the phone company's equipment to think you answered and the ringing stops, but since the machine hasn't picked up the call then disconnects. If you have the same problem with a different phone, you'll need to contact your telephone company. They can test the line to determine where the trouble is. If it's in their outside wiring (moisture in the line or other defects), they would be responsible for fixing it. If the problem is in your inside wiring they will probably charge to come out, so they can provide some troubleshooting tips.
If another phone rings in properly, there is something wrong in the fax machine's line connection circuitry. Then you'll need to see about having the machine serviced, or consider replacing it.
Dec 07, 2010 | HP 1040 Plain Paper Inkjet Fax
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Lands Phones
Answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
Mar 28, 2008 | Uniden Cordless Phone
I can not get my phone to pick up on the answering system when a caller is trying to leave a message
Try looking underneath the console of the answering machine. You must turn the answerer on on most machines and underneath there may be a switch to determine how many rings before it picks up as well.
Dec 26, 2007 | GE 28111 Cordless Phone
Lands Phones Logo
515 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
