Question about Philips Magnavox 32PS55S 32" TV
Actually, I have an 29PT468A
I am unable to use the video inputs at the top rear of the set. Using the AV button on the remote I can only get the standard analog input and then Video 1 and Video 2. Should I get an OSD message that says Front or is there another video channel that I can't find?
This should be the 'camcorder' position. It is after Video 2 as you go through the channels.
Regards Clayton.
Adelaide, South Australia.
Posted on Jun 18, 2008
SOURCE:
Hi, how do i change the input mode so i can play music from a device through the television using these inputs.. (model type Logik L29HE12)
press the source button on your remote and select av
its between the channel and volume buttons
or press source on the buttons on the top of the tv
select av
Apr 04, 2018 | Televison & Video
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
How to I change the video input? i.e. I got a digital TV box and need to put it to video input 1. How?
  • On the back of your TV are all your inputs/outputs.
  • On the far left is your Video 1 Input.
  • The top input is your Video (Yellow AV cord)
  • The middle input is your Left Audio (White AV Cord)
  • The bottom input port is for your right Audio (Red AV Cable)
  • After you have all the AV cord up as I have explained then push the "TV/Video" button on the remote until "Video 1" appears on the screen.
  • In the event you should want to use Video 2 sometime then hook the cords up the same way except in the Audio 2 port in the back of the TV.
  • Each time you press the "TV/Audio" button you will cycle through the Inputs until you come back around to TV.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 13, 2011 | Panasonic CT-32SL13 32" TV
Can you hook up a DVD player to this TV? It is a DTQ 13V5FC purchased in 2003.
I took a look at the specs for this set, and it has both front- and rear-panel audio and video input jacks. There's a button marked "VIDEO" on the remote that switches to the AV input so you can watch what you have connected. So yes, you can hook up a DVD player, but there are some limitations.
This isn't a stereo TV, so you'll need a Y-adapter (like this one from Radio Shack) to combine the right and left channel sound from the DVD player into a single mono input for the TV. This means you'll lose any stereo effects from the DVD. Also, even though there are two sets of AV input jacks, the TV can only use one at a time. You can't select the front or rear input separately.
Hope this helps. Thanks for using Fixya!
Mar 26, 2011 | Daewoo DTQ-13V1FC TV
I can hear the tv but no picture.. i remove the red, yellow, and white cord from the back of the tv to dust...pls help.. Apex tv brand
Hi! Welcome to Fixya!
If you are unable to view video on your television set, the issue may be that the TV's video input selection does not match.
The TV input source must match how the equipment for example DVD is connected to the TV.
* Plug the RCA cables(red,yellow,white cord) to the designated ports.
* Grab your Apex TV remote and attempt to cycle through the video inputs by hitting the "Input" button at the top of the remote multiple times.
* If you have used a DVD player or similar external device recently, you may have neglected to switch the video input back to the one assigned to your TV programming.
* Devices such as DVD players often reside on the AV 1 or AV 2 video input, and failure to switch back off of one of these will result in a dark, soundless screen when attempting to view cable or satellite television.
* Cycle through the inputs until you land on your cable/satellite input once more, which should result in an immediate restoration of picture and sound.
* If it does not, approach your Apex TV and look over the A/V cable connections. The A/V cable has two sets of prongs, one on either of its ends. Each prong is either red, yellow and white, and plugs into corresponding A/V ports on the back of the Apex TV and the back of your cable or satellite box. Make sure the ports and prongs are color-corresponding and have not been switched up.
Thank you for using FixYa. Keep me posted. :
Mar 12, 2011 | Televison & Video
How to switch to av rca input channel
hi melinda,
u can go to av input by simply pressing the VIDEO button on ur remote. when first time u press the first input may select. press again and again until u get desired input. normally rca input may be video 1 , or video 2 . first check which input are u using. select the same using remote. To return to tv mode just press TV button on the remote.
ok
Dec 13, 2010 | iLO 2600 Television
What channel do i use to use the DVI entry?
None, channels are only on the tv source entry. The DVI is just another AV entry, to use it you just select it from the other AV sources.
Jul 05, 2010 | Hitachi 51F500 51" Rear Projection...
I can't get the channel select to go to av input or video input
A universal remote in most cases can not switch this TV into the AV mode...you can but a orignal replacment remote for your TV At www.remotes.com and then you can use all the functions again!
That will fix ya!
Please rate my response!
Thank You!
Jan 17, 2009 | RCA 32V430T 32" TV
Unable to switch on DVD function on a Bush 14" combo
Switch on t/v press TV / DVD button on remote to ensure it is in TV mode. Select DVD by pressing
AV button once or by using input select menu
Press TV /DVD button until DVD RC appears on top left (The remote is now set to DVD mode)
Insert disc ensuring label is to rear of set and Auto play function will start
Oct 10, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Philips Magnavox 32PS55S 32" TV Logo
63 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
