Question about Whirlpool ED5SHAXM Side by Side Refrigerator
Rattling in water line to refrigerator
When faucets in house are turned off, or when toilets are flushed, water line to fridge starts shaking and slapping poly line behind said fridge. It lasts for approximately 7-10 seconds. My concern, beside the nerve-racking sound, is that something will eventually shake loose and leak.
My Question: How do I make it stop?
Note: I did install a bleeder valve in my attic plumbing, thinking that would "burp" air out of the system, but that didn't do it.
    Genius:
  • 1,073 Answers
It is a home plumbing issue not a problem per say with the ref. it just happens to be the end result, nothing that can be added to the ref to stop it
Posted on Apr 15, 2008
SOURCE:
AVibrating sound for 10 seconds- like a moan- after toilet is flushed and filled.What is going on? It doesn't happen every time.
Depends upon several things, the most difficult would be too much air in the pipes. Before having a "anti-hammer" installed; I would try this... go to the supply for the cold water pipe (for that room, dependent upon the age and style of your home) maybe the basement??? See if there is a place, other than the toilet, to turn off the water supply (turn the water off), open the cold water valves of your sink and tub and flush the toilet, and drain about 1 quart of water from that line. Leave the tub and sink cold water valves open and slowly open the valve you turned off, allow water to flow from the faucets and flush the toilet a few times. What you are trying to do is allow the air to escape. Turn off the faucets and flush the toilet again, open the partially closed valve all the way. This should get rid of trapped air, and it is the cheapest first step. This is one example of an "Anti-hammer" device.
Note: On some houses it may be difficult to find a place to drain the cold water line, without turning off the entire home.
Jan 15, 2018 | Home
What is causing air in my cold water line and how do I fix it?
try running all the water in the whole house at once. all toilets. outside faucets, washing machine, ect...
assuming you have no leaks.
Aug 25, 2014 | Home
My amana side by side fridge water dispenser drips and seems to drip a lot more when say the toilet flushes or the washing machine is running almost like it starts a siphon
Sounds like you need to replace the water solenoid valve, located where the water line connects to the back of the fridge, usually behind the fiber cover at the bottom.
These valves are damaged by dirt in the lines. Dirt and scale roughs up the valve needle and seat, and leak more with lower water pressure.
You can get valvesand valve kits from appliance part stores, Home depot or sears parts via ordering. I highly suggest an external in-line filter that will stop this forever, and suppliment the internal filter for taste. If particles are damaging this valve, it is also slowly causing damage to the other water valves in the bathrooms and toilets. If you have to replace valve washers a lot, then a whole house filter would be worth it.
Jan 08, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I have a Grundfos Comfort System. At the tap farthest from the hot water tank, I get a tremendous amount of grainy residue from the tap. No other taps have the residu. I've replaced teh water softener,...
Sounds like you have sediment built up in the pipes, and maybe the furthest faucet is the gathering place.
Take off each shut-off valve at furthest faucet and connect a water hose that flows into nearby toilet bowl.
You can buy garden-hose-to-1/2-pipe adapter at hardware.
Open water so it flushes the line into toilet bowl.
Then clean out valves and reassemble shut-offs and grundfos connection.
Remove faucet aerator and flush line up to faucet.
Install new aerator.
Dec 30, 2010 | Grundfos Comfort System Recirculator ...
After I flush the water pulses and shakes the pipes,why
washer on stop probably came loose and obstructing flow enough to cause shaking...need to shut water off to house and check the stop undr toilet
Nov 21, 2010 | Toto Aquia II Dual Flush Toilet
Only hot water in sink/basin when the toilet is flushed
I always think I have heard it all at times and then a story like yours rolls in....Please call a plumber,I know what I am doing and you are not going to be able to solve this online. The faucet and toilets are never plumb together much less 2 areas as you have ...so please call a plumber this time...Please rate and this is not Inappropriate.Thanks jj505. Any other ?s please ask. Are you in Ga.30097
Apr 06, 2009 | Plumbing
Only hot water in sink/basin when toilet is flushed
I had a customer a few weeks ago that had the same problem. When the water heater was installed they crossed the supply lines. They had the inlet as the outlet. Esentially, the water heater was plumbed in backwards. Also there could be a miss piping somewhere in the house but it would probably be near impossible to find it right now without tearing up foundations. Also check that the faucet is not plumbed backwards as well. Especially if this is a single handle faucet that you are referring to.
Apr 06, 2009 | Rheem Tankless Hot Water Heater...
Water keeps running even when turned of to the house
No problem on this one. Turn of the valve to the toliet just above the floor next to or behind the toilet. Go turn on a outside faucet. Is there still pressure? Wait a minute if it seems like there is still pressure to let the line pressure go down, what this is just water in the line left over. If the water stops on the outside faucet then the water is off. If you do not have a outside faucet then use a tub or a sink faucet. (if it does not stop then see part 2)....Keeping the toilet valve off remove the supply line from the toilet where it connects. This sould be the larger end. Is it is a flex line this should make it easyer. If it is a hard line like copper tubing, stop and go to the hardware store and a buy a flex supply line. This will make your job a lot easyer. After you remove the part of the line that connects to the bottom of the toilet then find a bucket place the end of the line you removed from the toilet into the bucket ( you may have to place the bucket at an angel to do this. Now turn the water valve at the wall for the toiel back on and drain the line. You may have to empty the bucket a few time but the line sould drain out.
( Part 2) If the water to the house is still on you need to go to the water meter and turn of the curb stop, this is going to be the valve inside the meter box ( if you do not have a well) and are on public water. You will need a cresent wrench, sometimes these valves can be hard to turn so you may have to use a little force. If you are on a well the you need to find the valve in you well house and turn it off. If you need more help or this did not solve this problem the repost and I will check back in a little while.
Feb 08, 2009 | American Standard Plumbing
SHOWER HOT WATER SCALDING
hi as you are probably aware ,when the toilet is flushed the water pressure to the shower is reduced so you get hot/scalding water unfortunatly there is NO easy solution you could put a needle valve in the supply to the toilet and with trial and error by turning the valve down reach a compromise between the time it takes to fill the flushing tank and the shower temp the only real solution is to feed the toilet and shower off independent supplies but in most houses this is impractical if not impossible silk090
Jan 08, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Fridge making "knocking" noise
Remove the light shield and there should be screws under it. Remove the air tower in the back, it snaps in and there is 2 screws behind that as well to remove the damper housing that sits behind the light. Also not sure what your model is but some models have 2 air ducts that run up each side, they come out after the light shield is removed by sliding foward and then pulling down. After the screws are removed in the upper plate the light assy will snap out and there is 2 quick disconnects on the wires.
Jul 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool ED5SHAXM Side by Side Refrigerator Logo
1,460 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
