There is a way to program this remote to devices without the codes. If it is possible to install the device to this remote at all, this will do it. This is an alternative method to programming your device without using the code list. The remote control will scroll through the list of codes to identify the correct code for your device.
Turn onthe device that you want to set.
Aim the remote control at the device and press and hold down the CODE SEARCH button for at least 3 seconds until the red LED lights up solid red.
Press the device button for the item you wish to program, e.g. TV,DVD,VCR, etc. and the LED light will blink once and then remain solid red.
Press ON/OFF button on remote slowly and repeatedly until the device you are trying to program shuts off. (Note: LED will blink once each time you press ON/OFF button).
Once this occurs, press ENTER button to store the code and the LED light will turn off.
To find the codes to program your dvd into the Innovage Jumbo Remote, you can look your brand of DVD up in a list, or you can use the automatic Code Search function.
Here are the Code Search instructions:
Turn on your DVD.
Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
Press the DVD button on the remote. The LED will blink once and then remain solid red.
Press the ON/OFF button on the remote slowly and
repeatedly until the DVD turns off. The LED will blink once each time
you press ON/OFF.
Once the DVD turns off, press the ENTER button to store the code. The LED light will turn off and your remote control is now programmed for that DVD player.
I found that on the back of the 2205 it said that the unit was made by Funai. I looked in the Innovage book and found that the codes for Funai DVD are 231 and 233. 233 worked on mine. Good luck.
