Open the following link and install the driver.
http://support.visioneer.com/products/8700/downloads.asp
If this helps you then please vote 4 thumbs for it and thanks for using fixya
You will have to uninstall the device. Delete any files it created on the drive as part of the install. (Not things you'[ve scanned, just program files) then disconnect the scanner. Reattach the scanner in a different USB port (different SCSI id if your using SCSI) and let Windows re-detect the scanner.
This time don't run the setup from the driver CD. Instead let Windows find the scanner and try and set it up on it's own, if it prompts you for a driver, point it to the INF file in the installer directory. If it doesn't, let it use the one it chooses.
After installing in this way you should be able to use the scanner as a TWAIN source from any application.
