Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
White spots on DLP TV
I have a Mitsubishi WD-C657 which is less than one year old. This TV has a "constellation" of six bright white dots, each about 1/16", and if you look very closely, there seems to be a faint "smear" from the corner of each dot. The dots are present whenever the TV is turned on, regardless of the source, or even with no input at all (blue screen). They are always in the same location, and they are not on the surface of the screen, but are dots of light coming from within the TV. They are visible (and stationary) right through any image on the TV. I have tried "re-setting" the TV, to no avail. Any assistance would be greatly appreciated, thanks.
  • 6 more comments
  • Cirrus9 Mar 21, 2008
    Jaime,
    Thanks for your quick response. I\'ll check the light tonight when I get home. Would dust or contamination on the light cause bright white spots(which is what I have), or dark spots?
    Thanks again,
    Jon
  • Cirrus9 Mar 22, 2008
    Took the back off the TV, cleaned the light and the mirror. No change. I guess what I\'m looking for here is someone who has actually encountered and fixed this problem before, and actually knows what it is from experience. Anyone out there?
    Thanks, Jon
  • Cirrus9 Mar 26, 2008
    BTW, although the TV is less than a year old and I am the first owner, I bought it from a wholesaler, not Costco, and I do not have a Costco receipt; therefore Mitsubishi will not honor the warranty.
    Anyone have any experience with this problem?
    Jon
  • Cirrus9 Apr 07, 2008
    Thanks for your input. Here\'s an interesting development - some of the dots have disappeared on their own (?). Four of the dots are gone, but nothing has changed now in the last week, so I\'m assuming that I am stuck with the remainder. All I have done is play DVDs via the HDMI input. Does this add any useful information? What would cause these dots of bright white light to appear and then disappear on their own? The video is not really "distorted" if I understand your meaning - just bright pinpoints of light. I think you are narrowing it down correctly to the optical engine (color wheel?) although I don\'t know a lot about what makes this up. Something is allowing the lamp light to pass through, and yet blocking the "coloring" of that pixel - and it\'s something that can come and go. Does this information help to narrow it down further? Thank you, Jon
    This is not a CRT TV with a tube, it is a DLP rear projection.
    Thank you for your reply. The brightness setting is on "Natural", and I don\'t have small dark spots, I have small pinpoints of bright white light.
    Thank you, I can see your logic, and I can understand why we might consider this; however, the same spots have appeared in the exact same locations when the TV has been located in three completely different buildings, with different setups. This is good creative thinking, though, and I appreciate your input. Jon
  • Cirrus9 Apr 15, 2008
    BDG,
    Thanks for your interest... this is really interesting. One by one, the dots of light have disappeared on their own over a period of a few weeks, all except for one. Last night I was watching a movie, and the last dot was gone. Then, ten minutes later, it was back again, and then gone, then back in randomly timed cycles. Clearly this is not physical particles but something electronic turning on and off. Oddly enough, I can\'t find one scrap of information on the web that tells me what\'s happening, and nobody on this site seems to have any experience with it. Mitsubishi seems like they might cover it even without the reciept, but I put that on pause when the dots started disappearing on their own. It\'s a mystery, but one that just might fix itself.
Buy a new DMD Chip for your projector should fix the white dots problem. Find a new chip at http://goo.gl/MJInrG
Posted on Oct 07, 2013
    Genius:
  • 3,422 Answers
It sounds like you are describing deal pixels in the screen.
These show up as small dark spots. You may want to get a magnefying glass and look closely at them. They can be a single spot or a group of them.
See if the brightness level that is below the default "Normal" setting.If the the brightness setting is too high please lower it.
If you still face the same problem then the only solution to fix this problem is to get it repaired.
Goodluck,
Please don't forget to rate the soution
Posted on Apr 06, 2008
  • Sony Master
  • 8,617 Answers
Those chassis's have been plaqued with bad capacitors on all boards. however any distortion of video can be traced to the 1000uf@16 volt capacitors on the FMT board, However due to the fact that this is apparent even without video (blue screen) your problem is the optical engine or defective lens assemly. I have done alot of repairs to those DLPs and they are difficult to work on. I wouldnt attemp it without a good service manual and alot of patience. If you need further assistance please let me know.
  • Sony Master
  • 19,396 Answers
If the spot stay always in same position, and it is like they are 'holes in the glass' from which the light from projector is passing by, then it is the screen of tv tube that is defective, in this case you will probably need to change the whole tube to fix the problem. In some unfrequent case the tube is fine and you need to replace the CRT board.
If you have blurred spots appearing on screen in different positions instead, you may need to replace one of convergency IC. If additionally tones in one color are fading you may need to refill the coolant, or to replace the crt board.
Regards
  • Ginko
    Ginko Apr 06, 2008
    I think Mitsubishi will honour 12 months warranty, providing that you have your model number available Contact them here and find out.
  • 3,037 Answers
This sounds like interference.
Could be some electrical interference or maybe from any distribution or amplification that you might have.
You need to work out a process of elimination, change old needs whenever practically possible and use RG6 quad shield leads and see what happens.
Please let me know if you need any further help
Thank you and good luck
  • Benjamin Patri
    Benjamin Patri Apr 07, 2008
    ok, sounds good, please keep us updated
  • Benjamin Patri
    Benjamin Patri Apr 13, 2008
    were you able to fix this problem at all? Please let me know how it all turned out.
  • 2,323 Answers
If your TV is less then a year old, I would suggest to call the manufacturers and ask them for an authorized service center to get it fixed.
If that is not possible, the spots could only come from the light itself. I would suggest to check the light for some dust or any other particles that could be blocking the light source. The light may also have that contamination internally, if that is your case the light will need to be replace or you can leave it that way until is time to change the light.
Let me know if you need further assistance.
Posted on Mar 21, 2008
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
We are having white dots appearing on our Mitsubishi DLP 65 inch television, approx. 3 years old. It looks like a constellation is appearing. New dot every day.
That means you need to replace the Optical Unit Block/Light Engine.Dmd board has been known to cause this also, but most of the companys replace Dmd and optical unit.
PTS rebuilts Light Engines 1-800-844-7871
Encompass Parts Distribution List this Model /Parts 1-800-638-3328
Jun 27, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
White dots on screen
I developed white spots on the screen of my Mitsubishi WD-57734 in increasing numbers over days and weeks. I called a repair service who quoted me $1500 to replace the light engine. He suggested I call Mitsubishi Customer relations at 800-332-2119 option 5 which i did. To make a long story short after several conversations with them they agreed to replace the part for free if I picked up the labor (Would have been less conversations if I had the original purchase receipt). Instead of $1500 I paid $250. The tv was only 3.5 years old. Perseverance paid off.
Jun 17, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have White and black dots on the screen of my Mitsubishi wd-73833 tv.
Jun 17, 2011 | Mitsubishi Televison & Video
I have white spots and black spots on right side of Mitsubishi WD-C657. I've done research online, and have heard its the dlp chip. Is that true, and if so, is it something that I can replace myself,...
This tv is it the DLP projection light engine block main board itself is the problems,not easily to go into the tv itself and replacing the IC chip itself.Must take out many mechanical parts to get u the Light engine block it self.U can replaced IC but somethime the IC chip it replaced,will not solved the problems,because the tv problems now the it is spreading and going on beyond the IC chip itself.If want to keep this tv very exspensive repair,i would reconmend hire a bound qualify tv tech replaced the whole Light projection block itself,but first call Mitsubishi for some kind of deal,they might help with the repair amount cost.
May 13, 2011 | Mitsubishi WD-C657 65" HDTV
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
I have a Mitsubishi WD-C657 with white spots all over it, its just over 2 years old (25months). I called Mitsubishi and they do not have a authorized tech in my area. They need an estimate before they can...
I have the same tv with the same problem and have found it to be the dmd chip which controls the mirrors. Once the chip begins to go it just gets worse and eventually will have to be replaced. Unfortunately you can't just go out and buy one and replace it yourself. It is mounted on the light engine circuit board and I got an estimate on the light engine from an authorized service representative and the cost for the part alone is about $900.00. The white spots are when the mirrors get stuck in the on position and if they get stuck in the off position they display a black dot, which I also have some of them. In a month's time my tv has gone from no dots to over 100 now. I have been searching to see if there is anyone who repairs the light engines instead of buying a new one, as this would surely be cheaper and I found a company that does this, but they will not do business with consumers only repair services. They are Hong Video Technologies, so if anyone out there knows how to get these engines refurbished and what it would cost, we both would be very appreciative.
Thanks
Jul 08, 2010 | Mitsubishi WD-C657 65" HDTV
I have a Mitsubishi DLP WD-57734 and white spots just started appearing I have owned the TV for 2 years and only one person in family uses it and not video games have replaced the lamp on time
The projection engine have problems,it the cause.Two years tv shouldn't have this problems already.Call talk to mitsubishi,might get some help the cost of the repair.
Jul 03, 2010 | Mitsubishi WD-57734 57" HDTV
Mitsubishi dlp tv WD65733 has white spots, like stars on screen, what causes this
If you get White or black dots all over the screen (DMD symptom)
If you get a pixilated picture (DMD Board)
Mar 27, 2010 | Mitsubishi WD-65733 65" HDTV
White dots appearing on Mitsubishi 1080p DLP tv.
Actually you must replace the DLP chip that is buried deep in the works of the tv. Unfortunately this can run into a nice lump of change. Do what I did. Perhaps you've heard the old addage
Mar 05, 2010 | Mitsubishi WD-73734 73" Television
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
202 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
