Question about Wacom Intuos3 6x11
The cursor stops moving.
Very often now and then when I lift my hand up to type (or whatever,) the cursor would stop following the stylus when I go back to drawing again--causing me a great deal of annoyance. Sometimes it seems to be fixed by switching to eraser side and go back to pen again, and other times not. I've never had this problem before when I was still using an intuos 6x8, but it happens every single time when I tried to draw after I switched to wide screen monitor and 6x11. A friend of mine who also uses the same tablet also experienced the same problem. Is there any way to fix this?
  • 1 more comment
  • Anonymous Sep 23, 2008
    I have the exact same problem. I have a wireless router and a 23" AppleLCD  monitor. Funny thing is, that when I swap to my Airbrush pen from the standard grip pen the problem disappears. Weird. Any other solutions would be appreciated.
  • Anonymous Oct 20, 2008
    I have the same problem, working on a MacG5, tried it today on another Mac and the rpoblem was gone, so I think it is somewhere outside the tabllet itself.
    I'll keep looking for a solution.....
  • evedder2k Apr 21, 2009
    Same exact problem for me.  It gets really annoying after typing something, then having to flip or wave around the pen like a *******.
I have found the same problem here. I use my plasma as a monitor and that interferes with the tablet when up close.
I also read somewhere it also can be your wireless router that causes the same problem. Perhaps using a different channel in your router preferences.
Posted on Apr 02, 2008
SOURCE:
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
Unstable, jittery cursor
Lets give this a try: Click the Start button> click Control Panel> click Hardware> and then click Mouse. Click the Pointer Options tab, and then do the following: Uncheck the Hide pointer while typing box. Hope this helps you. Let us know either way. Make it a great day!
Apr 30, 2012 | Compaq Computers & Internet
When i am typing the cursor will suddenly move to the middle of what i have already typed , it is driving me potty and i have to keep re typing things , is there anyway to stop this? sunshine
I was experiencing this problem before, and I figured out I was tapping the touch pad with the palm of my hand. I had to download a driver for my touch pad and adjust the sensitivity of the touch pad.
Mar 01, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
How do you replace ink in EPSON TX110? Paul
The procedure is shown on the panel you can see if you open the cartridge compartment of your TX110. However, it can take some effort to decipher the icons. It is known to work if the ink low light is on, untested otherwise.
  1. Turn on the printer.
  2. Press and hold the STOP button until the cartridge tray moves out of its bay. It will stop at the ink low notch pointing to the first cartridge out.
  3. Press STOP again. The cartridge tray will move to show you the next cartridge low on ink.
  4. Repeat until you know all cartridges out. After the last cartridge pointed to, the tray will move again and stop in the area where all cartridges can be accessed by hand.
That's it folks!
Nov 12, 2009 | Epson Stylus NX400 InkJet Printer
Can not get carrage to stop in change position epsum stylus x200
Turn on printer, and unplug power while carriage moving. Then move carriage by hand freely to replacement position.
Oct 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I am having a problem when I type and the cursor moving
This happens when your hands get to close to the palmrest and your wrists are actually causing the cursor to jump to another spot. Go to the control panel > mouse> settings > highlight the touchpad listed and select the settings button. Look through the entries and there is a setting for palmrest sensitivity. Turn down the sensitivity so your hands and wrists don't trigger a cursor movement. The hardware and drivers are fine, this is a setting adjustment.
Oct 10, 2009 | HP Pavilion DV6700T Notebook PC
Computer says black ink is low. Ink light is flashing on Epson Stylus NX100. When I hit stop button to begin replacement it wont move cartridge
***hi there,il be willing to help you on that. ****
1. Turn on the Epson Stylus NX100 Series.
If a cartridge is expended, the ink light on the control panel stays on. You must replace the cartridge to be able to print.
2. Open the scanner and prop it up with its support.
3. Press the Stop button. The print head moves to the position to indicate which cartridge is low or expended.
4. Press the Stop button again.
If another cartridge is low or expended, it moves to the position. Press the Stop button again to see if more cartridges are expended.
If no other cartridges are low or expended, the print head moves to the replacement position on the right.
5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
6. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.)
7. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
8. Remove the yellow tape from the bottom of the cartridge.
9. Insert the new cartridge into the holder and push it down until it clicks into place
10. Once you replace all the necessary cartridges, lift the scanner slightly, release its support, and lower the scanner
11. Press the Stop button to begin charging the ink. This takes about 1 1/2 minutes.
When the On light stops flashing and remains on, ink charging is finished.
Caution:
Never turn off the Epson Stylus NX100 Series while ink is charging or you’ll waste ink.
If the ink light flashes, press the Stop button and press down all the cartridges securely.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jul 13, 2009 | Epson Stylus NX100 InkJet Printer
I dont know how to allign my i mate pda 2k. how? pls help me.
Go to the "phone programs" screen page and at the bottom left,select the touch screen allignment option.select and follow the instructions.You will have to continue tapping the cursor till it stops moving.Then your screen will be alligned.
Jul 03, 2009 | i-mate PDA2k Pocket PC
Inability to load new cartridges
Keep pressing the button to the left of where is says 'stop'. Eventually it will stop on the right hand side and you will be able to lift the grey bar and get to the cartridges
Aug 12, 2008 | Epson Office Equipment & Supplies
Wacom Intuos3 6x11 Logo
1,906 people viewed this question
Top Wacom Computers & Internet Experts
Edward Easley
Edward Easley
jasbo
jasbo
Alun Cox
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
