SDM HS73 ''turns off'' sometimes. It is absolutely stochastic. I use '''' because I'm not sure whats going on. Toggling the off-on button rarely helps- it comes on for a second and blinds again. BUT : if I connect remotely to this computer (RDP) - it wakes up!! (and I get there the login screen)and this is absolutely shure, I tried it a number of times. Power/screen saving on the computer is turned total off. Does somebody has an explanation?
Miro
One thing I know for sure on this model HS73/HS93 is that the backlight assemblies failed due to poor soldering works. This may the problem with your monitor.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
It is very time consuming repair works that I doubt very much if repair shop will do the work.
When you use Remote Desk top, the monitor that is connected to the remote computer does not need to be on, I controlled server computers (5) from home to do update and back up, the servers are connected to KVM and with one monitor, one keyboard. May be you should try this monitor with other PC, if it does not come on, then you need to open it up or take it to the repair shop.
Does the monitor work with other PC?
no solution, no explanation...
What I'm wondering is: how is RDP affecting the monitor - RDP can not change the wrong soldings or4 blown caps... and it wakes the monitor ALWAYS!
