I am not sure, but I think the Brinkman uses the ignitor to light one burner and the other burners light after the first one allowing the flame to "crossover".
Jeanne - Did you remove the burner to clean? If not. you weren't able to clean the Venturi Valve, which is part of the burner. Spiders love to get in the Venturi Valve & build a nest. When that happens it stops the gas to that burner. I suspect, that may be the problem. The Venturi Valve, is part of the burner (the open end part) that's closest to you, when you face the front of the grill. It will look like 2 slots (one on each side) cut out of the burner tube, where it fits over the burner orifice. But, you can't see it, without removing the burner. An old tooth brush works well to clean it.
Hope this helped you to solve the problem. Please let me know and Happy Grilling!!
Sounds like the offending burners need to be removed, checked thoroughly for clogs and particularly the venturi valve on each burner. And while you have them out, remove the burner orifice of each burner and look for clogs.
Hope this helps you to further troubleshoot and solve the problem. Happy Grilling!!
Probably some of the winter crud has clogged the burner and or the venturi valve. Remove the burner, clean it and check the venturi valve for spider build-up. Wouldn't hurt to check the burner orifice too.
Well, I personally, wouldn't want to go from a 3-burner to a 2-burner because I think Weber designed the 3-burner grill to perfection, and as you know, all you have to do is turn off the middle burner.
At any rate, indirect is harder with the two-burner because of the placement of the burners. You can try to put some 1" thick ceramic bricks directly on the flavorizer bars in the middle, or if you are using a rotisserie, put a pan under your meat.
Sounds to me like the new burner that was put on, has the wrong gas orifice in it. Possibly a nat gas orifice instead of a propane orifice. If it's a propane grill, take it to your local propane co and have them look at it. Also, sometimes just a spiderweb or dirt dobber nest in the burner's venturi tube can cause that kind of problem. Blow it out with an air compressor and see if that's the problem.
Okay, what you are dealing with is called "vapor-lock". The way these grills need to be turned off is, close the tank valve first and after the burners go out, then turn the burners off. The way you are doing it is trapping the gas and you are getting a weak flame. Fortunately this is an easy fix. First, light the grill by turning the gas valve open, then turn the burners on to light the grill...as soon as that is done, close the gas valve on the tank then turn the burners off. Repeat this procedure until you get a good flame. If this procedure hasn't fixed the problem after the third time, you need a new regulator and regulators are easy to find in any home improvement store like Lowe's or Home Depot.
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
