I have a systemax laptop. While trying to install a mouse, the directions said to disable the mousepad. I did and now I need to enable it.
I think you can enable it via device manager.
which you will find in the system folder in the control panel.
Posted on Mar 21, 2008
6ya staff
SOURCE:
Hi, i hav a probook 4510s laptop & i cant get the mouse pad to work... when the lappy is starting up, in the left hand top corner is says - no mouse detected. please help!
If this is a recent occurance, shut down, unplug, remove battery, plug in, push the on/off button and do a System Restore to a date before this problem. Perhaps the TouchPad driver is in error. You can try a external USB mouse to troubleshoot the problem in Device Manager to verify the driver or device isn't in error. I think HP TouchPad software is Synaptics Pointing Device, check your your Tray Notification Area for the icon, right click, select Pointing Device Properties. Or Control Panel, select Mouse.
Nov 29, 2013 | HP ProBook 4510s FM849UT Notebook
Gateway laptop computer screen is upside down and can not use mouse
Shortcut Key To Flip The Screen In the Windows TO 180 Degree..
The shortcut is (or should be, read below**)
for normal windows : Ctrl + Alt + <Up arrow> (or shift+alt+<up arrow>)
and for 180 deg it is : Ctrl + Alt + <Down arrow> (or shift+alt+<down arrow>)
However, you should know that these are default shortcuts for
Intel Extreme Graphics Controller, and you can change them. To
check / change or disable these keys go to control panel->Intel Extreme Graphics->Hot Keys.
**sometimes the shortcuts do not work. This happens when you have not enabled rotation
feature in Display Settings under Intel Graphics Media Accelerator media. You need to
enable rotation in order to be able to Rotate / Flip your windows screen upside down / 90 / 180 / 270 degrees.
Mouse: with mouse, do you mean a usb mouse or the mousepad? if the mousepad isnt working, check ur "F" keys for an icon that looks like a mousepad icon. Then press the "Fn" key + the corresponding mousepad icon key and see if it works.
Oct 15, 2013 | Gateway CX2610 Notebook
Laptop wont move or switch off
please find some button near the mousepad. this is used to disable and enable the mouse arrow.. You might have accidentally clicked the button which disable your mouse.. so click it again to enable the mouse pointer.
I hope this is helpful to you.
Thanks
Apr 26, 2010 | Samsung NC10-14GW Notebook
Acer 4720z mousepad not working
You may have a function key that can enable/disable it or a setting in the control panel > mouse > pointing devices. Or possibly a BIOS setting to enable/disable.
Apr 08, 2010 | Acer Aspire 4720 Notebook
Gateway laptop running Vista suddenly developed an issue with the mouse pad.... double click doesn't respond. However the touch pad works to move the mouse
I have just had this problem with an Acer laptop running on Vista Home. When I double clicked on the actual pad itself rather than the bottons, it wasn't recognising it at all. Wouldn't scroll down or select a folder etc, just if I double clicked on the actual pad. Everything else worked OK.
I tried the solutions above but they didn't work.
Turns out it's the 'Tapping' function that needs to be enabled. Go to Start > Contol Panel > Hardware > Mouse > Device Settings > Then it says devices: and lists what pad hardware you have (mine is Synaptics Touchpad V7.2.
Under the box are 3 buttons Enable, Disable and Settings, presuming yours is enabled go to Settings > Tapping > Enable Tapping. Hey Presto! :-)
Aug 21, 2009 | Computers & Internet
Mousepad won't respond
go to control panel, performance and maintence, hardware, device manager, find your mouse, and then disable , then enable, if this dont work, update driver, also make sure it is turned on, go to control panel, mouses and keyboards, and make sure it is enabled there first.,
Jun 02, 2009 | HP Compaq Business Notebook NX9005...
LAPTOP BUILT IN MOUSE PAD
depending on what laptop you got i got an acer spire 5751z and it can enable or disable the mousepad by pressing 2 keys on the same time:
<FN><F7>
let me know what laptop you got or how it worked out
greetings
Jan 02, 2009 | Computers & Internet
Acer Aspire 3000 laptop
Hi, Try pressing the FN+F7 buttons together. This will enables or disables the touchpad.
Cheers!
Apr 12, 2008 | Acer Aspire 3000 Notebook
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
Permanent settings in control panel
function and f7 key disable and enabled mousepad
Oct 19, 2007 | Acer TravelMate 2300 Notebook
Open Questions:
AOL MAil SuPPoRt %%%{1=855=536=5666}#[email protected]@# CUSTOMER HELP AoL MaiL Tech Support Number @+1{{855%[email protected]!}} USA Login Repair service center to resolve all AoL MaiL customer service phone Number products.AoL MaiL is an American multinational company which was founded by Michael AoL MaiL using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, AoL MaiL support number, and selling of computer-related services and products. AoL MaiL Tech Support Phone Number Recently, AoL MaiL has been named the number AoL MaiL technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, AoL MaiL customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, ortonand Phone . Enter a AoL MaiL Service Tag or a AoL MaiL Get AoL MaiL Technical Support Phone Number and Customer Services. AoL MaiL is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, AoL MaiL Tech Support Number @+1{{855%[email protected]!}} USA Login Repair service center to resolve all AoL MaiL customer service phone Number products.AoL MaiL is an American multinational company which was founded by Michael AoL MaiL using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, AoL MaiL support number, and selling of computer-related services and products. AoL MaiL Tech Support Phone Number Recently, AoL MaiL has been named the number AoL MaiL technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, AoL MaiL customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, ortonand Phone . Enter a AoL MaiL Service Tag or a AoL MaiL Get AoL MaiL Technical Support Phone Number and Customer Services. AoL MaiL is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services. develops technology products. Basically, the company offers computer related products and services.
Oct 23, 2019 | AOL Computers & Internet
Computers & Internet Logo
Ekse
Marvin
Marvin
