Question about Frymaster Dean H17-SC Deep Fryer
Frmaster mj145ecsd Hi I was looking for the codes so I can reprogram my timer. I do not have the manual for this.So anything would help me out. Thanks Teresa
    Champion:
  • 254 Answers
Http://www.frymaster.com/?xhtml=xhtml/fry/us/en/general/onlineliterature.html
Here is the link for the mj series fryers. Yo may have to navigate just a little to find the information you are looking but this shoud put you in the right area.
Posted on May 31, 2008
SOURCE:
Need to know why the grasslin Fm/1 Digi 20-L timer won't let me program it. I push reprogram button And it went back to just blinking the days of the week on top but won't respond to anything I push
Likely solution: Current time of day was set without holding down the timer (or clock symbol) key.
Other possibilities: Maybe the back-up battery is depleted and you need to connect timer terminals to correct power source ... these models vary 24V, 120V, 208-240V... look for markings on timer
More possibilities: Troubleshoot following link: This is older version timer.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#module
Manuals on following link:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TRAX
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 11, 2015 | Hardware & Accessories
HI,I installed a GE digital timer model 15313 about two years ago.Now cannot turn on or off manually or program it. But it does turn on and off the times I programed the last. Thanks
Try reset and reprogram
If functionality is not restored, then replace timer.
Note also the load rating for each timer.
If you are operating above or outside the load parameters for timer, then timer might not function correctly or function as long as expected.
This timer, and most timers have 1 year warranty.
http://waterheatertimer.org/GE-timers-and-manuals.html#15313
Suggest replacing with 5-year warranty Ei600
Can operate any load value, LED fluorescent incandescent motor
Has dawn-dusk or programmable mode
http://waterheatertimer.org/Programmable.html#st01
Gene
Sep 02, 2014 | Hardware & Accessories
I have losts my manual to my ss7 intermatic timer. please help to reprogram.
Copy following link to identify timer and download possible manual from SS series Intermatic timers
Add a comment as needed
May 31, 2013 | Intermatic Hardware & Accessories
Need help programing lllwoods model 50000 indoor 24 hour mechanicl timer 2-c
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
http://waterheatertimer.org/Woods-timers-and-manuals.html#50006
If you have the digital timer, generally you can toggle DST back-and-forth 1 hour by pushing two buttons simultaneously for 3 seconds. And then reverse the setting again by pressing and holding both buttons again.
Open link. Download manual. Look for 'daylight savings time' in manual. Read instructions.
You can unplug timer to make programming changes, since the timer has a carryover feature against power outage.
To restore functionality of a timer that no longer works, press reset button and then reprogram.
The Woods 50000 series are new line of timer introduced just before Christmas 2012.
Woods timers are warranted by Coleman/ Carol Cable/ Canadian tire, and I suspect the timer itself is made by Intermatic.
All these timers have standard 1 year limited warranty against workmanship defects.
I have not seen any complaints about this line of timers here at fixya.
Add comment if you need more help.
Apr 18, 2013 | Woods 2C 24 Hour Indoor Mechanical Timer...
Can i down load the instruction to reprogram my timer.Gemodel#15086
Hi and welcome to FixYa, I am Kelly.
You can get the manual here:
http://waterheatertimer.org/pdf/GE-15086-Manual.pdf
Thanks for choosing FixYa,
Kelly
Sep 02, 2011 | Hardware & Accessories
We've lost the instruction manual for our light switch timer so don't know how to reprogram it. Directions, please!! We've just replaced the battery.What buttons do we press in what order to...
Question posted under Intermatic timer:
Open following link to identify timer and download possible manual:
IF Intermatic timer stopped working because battery failed, then all that's needed is to reprogram current time, because the original timer programs you set are stored inside timer forever until timer is manually reset using reset button.
If you have Intermatic ST01C timer, then open following page for ez instructions:
http://waterheatertimer.org/ST01C-program.html
If you need help programming specific timer, then get as far along in manual as possible, and then add a comment.
If you have different brand timer, than each brand has link that shows on Intermatic page.
Aug 10, 2011 | Intermatic Hardware & Accessories
Looking where to find an instruction manual to reprogram my intermatic astrological wall switch the e1600
You posted under E1600.
Maybe you have Ei600
Ei600 5-year warranty is heavy-duty version of Intermatic ST01C 1-year warranty
One thing to note about this timer, the programs remain in memory indefinitely until timer is reset.
You might only need to reprogram current time.
Open following link to identify timer, and download Ei600 manual, and read ez wiring and programming instructions:
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 30, 2011 | Intermatic EJ500C - Indoor Digital Wall...
Cant find my manual for my 39/08 universal remote to reprogram my LG flat screen tv.....help
Hey,
i wasn't exactly able to find the manual you were looking for. But in case you were just looking for remote control codes, why dont you try the following website.
http://www.xdiv.com/remotes/
Hope this helps.
Thanks
Apr 15, 2009 | Televison & Video
NEED TV CODE TO REPROGRAM MY REMOTE
Hi
Had the same problem but found a similar looking remote for the SDV593SU online and the codes work!
http://tv.manualsonline.com/manuals/mfg/toshiba/sdv593su.html
Cheers!
Michele
Nov 08, 2007 | Toshiba SD-V392 DVD Player/VCR
Frymaster Dean H17-SC Deep Fryer Logo
234 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Treefrog15
Treefrog15
Paul Carew
Lawrence Oravetz
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
