Machine wont spin or empty
The machine will fill and agitate but that is it. I checked the lid switch and it ohm'd out ok. I pulled the water pump off and bench checked it and it works. The timer switch seems to be working fine but I am unsure how to check it other than hearing it click away. Any ideas?
Thanks!!
  • 185 Answers
Check the pressure switch
Posted on Mar 26, 2008
SOURCE:
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
The machine fills and will not start agitating unless the lid is open and closed several times.
The most likely failure is the water level pressure switch or a failed lid switch. If the washer will drain and spin then it's not a failed lid switch. If it will not drain and spin the likely failure is the lid switch.
The water level switch (pressure switch) has 3 wires attached to it, V (violet), P (Pink) and a T (tan) wire. When the tub is empty of water, contact V&P are closed to allow the tub to fill with water. Once the water level reaches the desired setting, contact V&P opens and then contact V&T closes to start the motor agitating. So, with this said if you were to unplug the washer and remove the wires from the water level pressure switch and test to see if terminals V&T is closing by using an ohm meter would indicate if the contact is closed or not.
Jan 12, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
The knob for my Kenmore 500 machine for water level broke off so I ordered a new one. I did take back off of washer and found out later I did not have to. Neighbor showed me how to take off top part of...
It's quite possible that when you released the console to replace the water level switch you disconnected the Lid Switch.
If the Lid Switch is disconnected the washer will likely not agitate, spin or drain and you won't hear the motor.
Check for a white plastic plug connected to the console and another connected to the cabinet.
Aug 11, 2010 | Washing Machines
I have a whirlpool model LSR 8233JQ0 washing machine. The tub will fill and agitate but will not empty out or spin. I replace the lid switch without success. The machine makes a sort of ticking sound...
you say it wont drain the water??? if it fills, agitates , and doesnt advance past the first rinse cycle, it does sound like a lid switch issue, can you hear the switch "clicking" when the door is just about closed??? if not then its not recognizing the door and wont advance for safety reasons.and when you replaced the switch were you sure to remember ot replug the harness before reassmbleing the unit
Mar 25, 2008 | Washing Machines
Waterpump won't pump and spin cycle won't start.
one of 2 things are happpening iether hte timer is not sending down the power to operate the pump , or switch is not closing correctly to allow power to the pump
Mar 19, 2008 | Frigidaire FWS833A Top Load Washer
Washing machine fills, but won't agitate
my kenmore washer will fill up but it will not agitate.
Dec 17, 2006 | Hotpoint Aquarius WD63 Front Load...
Why wont my washer dryer empty the water...???
If the machine fills and agitates but does not drain, something is probably wrong with the drain hose or the pump. The fact that the washer fills and agitates tells you that the motor works and the belt is okay (though some units have a separate belt for the pump and direct-drive washing machines don't have belts). 1) Be sure the drain hose isn't kinked. 2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The water pump may be broken or clogged with a small article of clothing or the controls may be broken; call an appliance repairperson. courtesy "nagev"
Oct 24, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
142 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
