Question about Kicker KX400.1 Car Audio Amplifier
Kicker ZX500.1 Hooked amp up and for some reason it keeps shutting off
Not getting enough air to cool off amp, if amp is in an inclosed area with restricted air flow, amp will over heat and shut down, once the amp has cooled off, it will reset.
Posted on Aug 23, 2008
I have two 12 rockford fosgates p3 hooked up to and 350.2 kicker amp i just got them so i hooked them up and my amp will keep turning on and off
How may ohms are the p3's and how are they hooked up? Some amps won't handle less than 4 ohms bridged. Try running one sub to each amp channel.
Also check power and ground connections.
Useing too small of wire for power, ground can cause the same problem.
Apr 17, 2010 | Kicker ZX1500.1 Car Audio Amplifier
Amp goes into protection
make sure the impedance is right for the amp you're using. If you're using a 4ohm amp and a 2ohm sud that may be the problem. It may be overdriving the amplifer which is bad and can cause damage to the amp. Hope this helps.
Jun 01, 2009 | Kicker 12" Solo X Subwoofer S12X - 5000...
Cut out
rewire the subs-each sub you want in series=8 ohms per sub-then at the amp wire the two 8 ohm subs in parallel which brings the ohms back down to 4 ohms which is optimal for the amp and it shouldnt shut down on you any more-try that-good luck
May 30, 2009 | Kicker ZX400.1 Car Audio Amplifier
Kicker amp shutting off
hello my friend you should have the input signal set to 500 miliamps do not go over, another thing is that if you have good ground and the battery is good and it has the sufficient amps to push it.also the ohms of your spkrs are not too low,you need to check all that.
good luck
caypianan@yahoo.com
Nov 02, 2008 | Kicker 04KX250.2 Car Audio Amplifier
Goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker amps not working
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 10, 2008 | Car Audio & Video
My kicker amp turns off
It sounds like you may have the load impedance too low. How many voice coils per woofer? How many ohms is each coil? If you have DVC woofers, are the coils for each woofer wired in series or parallel? Are the speakers wired in series or parallel. Let me know if you need me to clarify anything.
Oct 05, 2007 | Kicker ZX10001 Car Audio Amplifier
Kicker KX400.1 Car Audio Amplifier Logo
164 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
