No Power Hi, I have a Sotec 3120 and recently it just won't power up. At first I thought it was the adapter, but I purchased a new one and it still won't power up or charge the battery. Could you please let me know why this is. Thanks.
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
First things first:
1) You maybe fried the onboard for Sotec 3120, using anothe Power Adapter that may have diffrent AMP. but same DC.
2) you can RMS your product, for a new one, if warranty apply **
3) Consult the manual for other way to power up your device at this point.
Posted on Mar 28, 2008
Hp pavilion dv6 2117ax will not power up
Since you already got a new charger, then the problem could be the power jack of the laptop and/or the connections inside the laptop.
Try to plug the power adapter slowly and try to wiggle it. It you feel that the power jack is wiggling, then the problem is a loose power jack that is why it won't charge. And you need to have a tech tighten that up for you.
Replacement HP Pavilion DV6 AC Adapter 65Watt 18.5V 3.5A Option
Oct 28, 2012 | Computers & Internet
Laptop wont turn on.
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
Aftermarket Car Headlights
Jun 11, 2012 | HP Pavilion dv6-1030us Notebook
My battery icon shows "plugged
When this issue occurs it is generally due to a bad power adapter. Power adapters tend to get hot when plugged in and in use. The actual temp inside the adapter would naturally be even hotter than the outside.
Over time wires inside any component that creates massive heat will simply breakdown. Sometimes they can get hot enough to catch fire.
My suggestion would be to purchase a new power adapter and see if that fixes the problem. You may want to find someone with the same laptop and "borrow" their power adapter to see if that fixes your problems. That way you won't spend any money until your sure.
THANKS! Hope that helps.
Aug 26, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Printer won't turn on and AC Power Adapter plug is making a humming noise.
hi
if the AC adapter is humming, refrain (stop) from using it !
the adapter is physically damaged and the internal transformer has been dropped several times to make such a noise.
you will have to purchase a new AC adapter, p/n should be and it should cost about $10-$15
ADP-25FB
pleae issue 4 thumbs up ... thanks for using FIXYA
May 10, 2011 | Lexmark X5150 All-In-One InkJet Printer
When i use my laptop, sometimes just leaving it alone or during a game the power switch to the battery. i checked that the power wire is connected but the led indicator on the wire is off. The only method...
Something is tripping the adapter protection circuit. Try plugging it into a surge protector or surge protected outlet. If it is still tripping you need a new power adapter. A PA13 is $10 on Ebay. Check the bottom of your laptop to see the power specs (90 watts or 65 watts).
Apr 04, 2011 | Dell Ac Adapter 0CM161 for Dell Inspiron...
Hi I just recently purchase online a epc netbook It won't even power on?
Hello
The problem you are experiencing might be the battery or may be the power adapter but since you said it wont even power on,What you need to do is to try and get a power adapter that you can test with your notebook to know if it is the power adapterthen you might need to replace your power adapter but If it doesn't work still then it could be the motherboard of your noteboook and it has to be replaced.
THANK YOU
Jul 03, 2010 | Computers & Internet
Gateway MX3231 won't boot and I just bought a new power adapter
Based on what you have stated, it looks to be your AC connector that is loose or broken from the motherboard. This connector just needs to be soldered back onto the motherboard. Have a technician look at this before you start spending money on a new battery.
May 07, 2008 | Computers & Internet
Power supply issue
sound like they have damaged the "new motherboard" when have installed it at the shop. Or they installed a cheap brand and it's not correctly sitting in the base. should ask them to show you the old motherboard they removed to make sure they haven't just fudged-up the old one.
Jan 13, 2008 | Acer Aspire 5004WLMi Notebook
Averatec 6200- battery
Are you using a travel adapter (converter)?
Nov 27, 2007 | Averatec 6200H Notebook
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
