Question about HP RT917UTABA - HP Promo dx2300 micro tower, Core 2 Duo E4300 80G hard drive 7200 SATA, no floppy, DVD-... PC Desktop
How to install a second DVD writer in an m8300f
I need instructions on how to install a second dvd writer in an m8300f. Which numbered plug to plug into the new dvd writer.
I have a cpu there is a dvd rom. but i want to make an additional dvd writter so i can burn movies and music.i want to know the specific steps on how to install a dvd writter to my pc.
thanks for your help.
nhick
Posted on Aug 17, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 194 Answers
For first dvd drive you have to put master jumper and for second you out slave then both drives work
Posted on Mar 24, 2008
SOURCE:
Need driver for tdk external cd/dvd writer model ded+880N
external writers are plug and play , they do not need a driver. the disk i think your referring to will only contain writing programs but there are many free writing programs on google search. just plug the writer into any usb port and windows will find it and install the drivers automatically
Jan 24, 2013 | TDK (DED+880) DVD±RW Burner
I have samsung n148 note book and i want to connect samsung external dvd writer what is the process
You just need to simply plug the one end (USB Type B) of the USB cable to the external DVD writer then plug the other end (USB Type A) to your notebook. Then, let your Operating System to automatically install the driver for your DVD writer. Let me know if this works.
Sep 29, 2010 | Samsung Computers & Internet
Dvd/cd writer how can i install i have no driver. does it plug and play
Yes! Optical disc drives like a CD/DVD Blu-Ray player/writer are usually plug and play.
Apr 29, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
My dvd writer not detecting dvds . ihave changed my dvd writer with a second hand writer but the problem is remain same
At your PC menu, left click Setting, Control Panel, and Add Hardware Wizard and get it open to find out if your DVD writer is installed and working properly. Otherwise, follow the instruction to get it installed. Thereafter, reinstall the software driver for the DVD writer. Otherwise, get your software driver download at the Internet, and install it in your PC. Just type at the Search engine blank( Download for software
driver Brand and Model of your DVDR,) and choose
the software driver applicable. Then, go back to your
PC menu, click open your download and have it
installed.
Nov 29, 2009 | Computers & Internet
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
New hp dvd writer... no sound from dvd's
First double click on speaker image in right corner of your screen to see if you have MUTE disabled for all the devices and you have audio drivers to have speaker activated. Second, if you recently istalled new dvd driver it can be hardware problem. There are audio plugs (analog and digital) on back of DVD-Burner. Check if they are connected properly. Third your DVD-playback software might not supporting audio, so you might be missing audio codecs to playback DVD-audio. It depends which program you using. Maybe you need to download another program to playback DVD, for instance Windows Media Player 11.
Good Luck
Dec 13, 2008 | Computers & Internet
Installing
Hi tatieyanah...
For installing your DVD Writer follow these steps...
First , Place your DVD Writer in a Suitable position and fix it by the screws.
1. From your CPU SMPS(i.e, power box) you will have many set of wires coming with white plugs.Take one of those wires. Plug that into your writer's back side.REMEMBER you should plug it in the way that Yellow color wire should in the outer end and two black wires in the middle and red at the inner end.
2. If you dont find any wire in your CPU , use the one which is given to you ,which is a splitter in the DVD box.
3. Use the data cable given along with the DVD writer. Connect that Data cable( cable which is Wide and looks like stripes) from ur Mother board to the back side of the DVD writer. Take care that it is not connected upside down.
IF U NEED MORE INFO, REFER "http://www.computer-adviser.com/how-to-install-dvd-writer.html".
Post me your replies.....Bye ...take care...
Sep 17, 2008 | Computers & Internet
Need to replace dvd writer ,model ts-h653 in a hp m8300f pc .
yes you can replace any dvd writer you want as long as it fits on the casing
Apr 08, 2008 | Computers & Internet
Philips DVD+RW
What is the serial number needed for as all dvd writer are plug and play with windows xp?
I pressume its for the burning software? xp has its own in built burner so its not really needed.
Jan 07, 2008 | Computers & Internet
HP RT917UTABA - HP Promo dx2300 micro tower, Core 2 Duo E4300 80G hard drive 7200 SATA, no floppy, DVD-... PC Desktop Logo
247 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
