Lg ptac heat pump/ac 12k btu 230v stamped allum grille installation
I have a ? about installing the rear stamped alum grille for this unit. It seems that the grille is to attach on the outside of the sleeve but it doesn't fit it has a slightly smaller dimension than the sleeve. if i install it just as the instructions say then the metal flanges are facing out and it doesn't look right. When I put it on the inside which barely fits i can get 4 grommets to line up and put the screws through from the back but that pushes the unit out . Does anyone have a solution? I double checked it is the correct grille but it doesn't seem to work any way I try it. Thanks
  • 86 Answers
1. open grill from out door box.
2 fix outer box where u want.
3 put a/c inside the out box
4 make proper wiring.
on the unit
Posted on Mar 28, 2008
User manual. Where can I get a copy
Pioneer Mini Split AC - Wholesale Prices, Open to Public‎
Adwww.highseer.com/Pioneer-HVACInformation & Support
Download Manuals, Parts Diagrams
Sales, Technical Brochures & More
Nov 08, 2015 | Pioneer Ductless Mini Split INVERTER Air...
Were dose the green wire go to my senville 18000 heat pump indoor unit
The green thermostat wire goes to the G on the terminal strip. If it's not a thermostat wire it is a ground wire Should be grounded to the metal case for safety. It does not affect the operation.
Nov 14, 2014 | Senville 18000 BTU Dual Zone Ductless Air...
Why doesn't the compressor start in the heat mode
Is it a heat pump? Is it a heat pump stat? Is ambient temp high enough to allow heat pump to run?
Sep 11, 2014 | LG LP153HD3A - 14,300 BTU, R410A, 9.4 EER,...
Flashes code ch09
check the control board. Make sure all plug ins are seated good if not seat them. If not I bet its your board.
Sep 02, 2014 | GE Zoneline In Wall Ptac Heat Pump Ac Air...
Heat and air unit heat stopped working
1-Check Thermostate for setting may wrong or Th. faulty.
2-Fuse near to heating element blown, Change it.
Nov 12, 2013 | LG Electronics 23,500 BTU 230v Window Air...
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
Is there a drip hole,itsgot water in it
Try Check on the underside, or sides near the rear of the unit (outside) you should see it there. Some have and some do not, most of the water evaporates, or Spills over the edge at the rear of the unit, if you have it installed correctly you should'nt have any issues with water in there.
Jul 04, 2012 | Kenmore 18,500 BTU Heat/Cool 230V Room Air...
Outside unit freezing over
check the outside drain in the pan if there is a plug in the bottom pull it out.the ptac unit will go into emergency heat and run more the colder it gets outside
Nov 23, 2008 | Amana PTH123B25AJ Heat Pump Air...
Will PTAC solve my problem?
Nope its a big room for 24000btu. the computation is 18sqm./ 1 ton. or 1.5 hp.
Mar 18, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
325 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
