Question about JVC Gumy Ear Bud Headphone - Peppermint Blue
Sound on headphones
Listening to my ipod on way home from college. I took out the inner part of the headphone out of the casing because there was a slight bit of dirt inside which i cleaned out. Attempted to put the part back in to the casing and ever since i have, the sound has been unclear, faint and not the original quality that i had previously. Have i damaged the headphones by taking them out or is there something simple i can do to fix them ? X
3 Suggested Answers
SOURCE:
Grubhead
  • 5686 Answers
SOURCE: My headphones only passing full
Try them in another device. If still the same contact the place where you bought them. If they work in another device, it could be your ipod socket is damaged.
Posted on Feb 08, 2011
mc1bean
  • 3053 Answers
SOURCE: I have a big problem
Hello, from my experience , some times its the batteries, when they get weak, that will happen. I have headset like that I use in my band i play in. Here is what happens to me, just like your problem. like i said earlier, batteries, or sometimes, there is something i have just recently installed in my house or moved in my house that is interrupting the frequency. The units are all based on a frequency like a garage door opener. I even one time kept during band rehearsal couldn't figure out why at a certain time i would get this static, come to find out, it was by daughter home at time of my practice, that was using hair dryer. What I did to solve this, was on my unit i can tweak or adjust on head phone and unit a different frequency, and dial it in. Also sometimes if you move your base station and put it on different outlet that is not on same circuit will solve problem. Please try some of these suggestions and see if any of there help you..... Thanks Mike.
Posted on Jun 30, 2011
My ipod nano has songs but no sounds
Step 1:
Since entering the marketplace and revolutionizing the way people experienced personal audio, Apple's iPod has become the unquestioned leader in MP3 players. Available in several different models and versions including the original iPod, iPhone, iPod Nano and iPod Touch the iPod allows people to listen to any number of songs with just the click of the button. However, as is the case with numerous electronics, certain iPod users encounter issues with their device, particularly sound issues. These issues range from buzzing sounds through the headphones to low volume quality to no sound at all. Fortunately, there are ways to attempt to remedy these sound issues.
Volume and Song Selection Oftentimes, those iPod users listening to heavier music (such as rock or hip-hop) will encounter a buzzing noise when playing their device at maximum or near-maximum volume. Try lowering the volume a bit, as this will most likely remedy your buzzing issues. Also, try playing a different song from a different artist at the same volume to ensure sound quality is optimal across the board. Check the Headphones Before attempting to diagnose an iPod's sound issues, ensure the iPod itself (and not the headphones) are the culprit for these sound issues. Do so by disconnecting headphones from the iPod and playing them on another device, such as another iPod, a PC or laptop. If the quality is still not optimal, the headphones (not the iPod) are likely the reason for low sound quality. Also try connecting an iPod to an iPod listening dock. If the sound quality is optimal, but not so when connected to headphones, that would also indicate headphones as the cause of low sound quality. b> Reset the iPod Sometimes, simply resetting an electronic device such as an iPod, digital cable box or video game system will remedy the solution, as it gives the device a chance to reboot. Try resetting the iPod to remedy whatever sound problem you may be encountering, whether it's no sound or less-than-optimal sound. Not all iPods are reset the same way, so consult the user manual (either paper form or through Apple.com support) to learn how to reset a particular type of iPod. Adjust Sound Settings If sound quality is less than optimal, including too much bass, not enough bass, poor acoustics or any number of other issues, try altering an iPod's system settings to correct the issue. Do so by going to the "Settings" key on the main iPod menu, then going to "EQ." From there, test certain settings to see if they may correct the iPod's issue. EQ settings allow users to set their music to a certain type of genre (in terms of how the music is delivered), as well as lowering bass, increasing bass and altering acoustics. b> Make Sure Headphones Are Fully Connected As simple as it sounds, sometimes the reason iPods have no sound at all is because their headphones become somewhat detached from the device. Such is the case with physical activities such as exercising or doing yard work. If no sound comes through the iPod, make sure the headphones are plugged in all the way to ensure the lack of sound is not a simple oversight. Consult Apple Support Whatever the sound issue, if iPod users have tried everything possible to remedy the problem with no results, they can call Apple support or visit an Apple retailer to help further diagnose the issue. The issue could be a simple fix or might be so severe that purchasing a new iPod is the best course to travel.
Feb 09, 2013 | Apple iPod nano 3rd Generation
Four weeks ago I bought an iPod Touch 32GB. After listening to my iPod on an external speaker I tried using the headphone and the sound is just too low. I thought my headphone was damaged but I tried it on...
Sounds like plugging the external speakers in has damage the spot were the headphones go in. If this is under warranty that bring it to apple store.
Jan 19, 2011 | Apple iPod touch
One earphone stopped working
not thrased jus yet wire in casing came lose needs to be resaudered
May 13, 2010 | JVC Gumy Ear Bud Headphone - Peppermint...
My headphones connect with the adapter, the blue light is on on both but nothing comes from the ipod. I have performed the factory reset but it still doesn't work. The headphones had worked fine and then...
I have same issue....just took my transmitter apart - the wires connecting the male jack to the silicon board are frayed, disconnected.....you might check that...it's only 2 small screws holding the outercase together....be careful though
Jul 07, 2009 | Logitech Bluetooth Wireless Headphones
Left ear no music
Before you worry about repair, verify that the balance control in the iPod isn't causing the problem. The easy way to do this is to try some other audio device (home stereo, etc).
Mar 19, 2009 | Coby CV-190 Consumer Headphones
HEADPHONES STOPPED WORKING BUT IPOD STILL WORKING
Oh, so there is no problem with the headphones. The problem is with the iPod.
There isn't going to be anyone to fix it back to normal without voiding the warranty except the Apple Corp. itself. Contact them with the details of the problem and they may ask you to send it back.
Dec 11, 2008 | Bose on-ear TriPort Headphones
Headphones gone quiet
Well, I think you've just blown them. I need more details...what music were you listening to? How loud? Etc.
Jun 08, 2008 | Sennheiser CX55 Consumer Headphones
IPod MA146LL/A no sound
You should check and see if the headphone jack is broke or not. That sometimes accounts for the reason why sound won't come out.
Go here to see about replacing/fixing a broken headphone jack:
http://store.ifixipodsfast.com/ipod-parts-/-installation/ipod-video/ipod-video-headphone-jack-/-hold-switch/prod_69.html
May 10, 2008 | Apple iPod MA446LL/A MP3 Player
Bad connection
It sounds like you have two problems. One is your ipod earphone plug ( phono plug ) needs replacing, and # two is your headphone plug needs replacing.
Nov 30, 2007 | Bose on-ear TriPort Headphones
JVC Gumy Ear Bud Headphone - Peppermint Blue Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
