SOURCE: Re: Location of the radiator drain plug on a 1998 Lesabre
its in the lower right or left hand corner of radiator.
refer to this links diagram for more help.
http://www.autozone.com/addVehicleId,2380201/initialAction,repairGuide/shopping/repairGuide.htm?pageId=0900c152800b1cd7
SOURCE: Radiator Drain Plug for Camry 99.
depends on what motor you have, it'll either be on the bottom of radiator (you might have to move the cover to get at it) or in the rear of the engine block. if you get at them i'd simply just remove the lower hose from the radiator. just make sure car is compleatly cooled down first.
SOURCE: radiator drain plug location 96 chevy 1500
Look on the lower right side(driver's side) of the radiator, It's down there.
SOURCE: Radiator Drain Plug Location 99 Astro
I have a 99 Astro & my drain plug is on the passenger side. Look for the small drain tube at the bottom of the plastic tank. The turn knob is right above it.
SOURCE: Radiator Plug Location
It should be on the right lower side of the radiator when looking at the engine .
