Question about HP iPAQ h6315/h6365 Pocket PC
Dead on board battery.
My soldered on the motherboard battery is dead on my ipaq 6315. I know how to take stuff apart and solder. How do I best get it fixed without an arm and a leg in price?? (Willing to mail it off and pay $$ if I really have to). ...walt
    Problem Solver:
  • 4 Answers
You can buy a new battery but you want to be sure of your ability if you are going to open the device and resolder it.
Posted on Mar 31, 2008
How to take apart an acernote 760ic?
The current CMOS battery is soldered onto the motherboard under the keyboard - you need to have soldering skills to remove and replace the battery or take the computer to someone who can do it for you. Be careful who you ask - that is a collector's item!
Sep 05, 2014 | Computers & Internet
The laptop doesn't boot. Its dead. I tried connecting the charger, but it doesn't shows any signs of charging. It doesn't even show the laptop is charging.i.e no led is lit when charger is connected.Please...
If it is completely dead check the voltage at power adapter DC contacts using a multimeter.
If there is voltage within 0.5 Volts from specifications, then try starting the laptop with no internal battery. A shorted battery may cause the laptop not starting.
If battery and adapter are OK, then the problem is the DC socket in the laptop motherboard. The laptop must be taken apart and the solder joints soldered back. This is a delicate job and must be done by an experienced repairer.
In some case the whole power circuit or the main board may be faulty. Testing is done reading Ohms at DC socket solder joints on main board (or power board, depending on model).
Aug 09, 2010 | HP Compaq Presario V5204nr Notebook
My Samsung 40" LCD makes a clicking sound and takes a couple of minutes to come on. What could be causing this?
Power supply board have dead componnent parts call capacitors,the board where the power a/c cord plug into it.That the power supply board.U know basic electronic's,have tools and soldering iron,desoldering pump or solder wick and solders?Searches all the power supply board for those dead capacitors.replaced it.These dead leakages capacitors alway bulges up on it tops or puff up on it tops.Replaced these dead leakages capacitors.Or tries websites like, to buy a whole refurbish power supply board for the replacemrnt.
Jun 19, 2010 | Samsung LN-S4051D 40 in. LCD Television
Turn tv on no picture everything else works. turn it off & on a few times maybe more and it comes on and stays on. what could be the problem thanks mike L
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check for bad soldering on the CRT ports and around the flyback transformer.
This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT port.
May 28, 2010 | Proview PA-32JK1A 32 in. LCD Television
Dead TV
U know basic electronic's,and u know how to do soldering?Have soldering iron,tools and solders?The power supply board,the board that the power a/c power cord plug into it.That the power supply board have these parts call capacitors are dead.These capacitors alway bulges up on it top or puff on it top.Check all around the power supply board and it supporting boards.Replaced these dead leakage bulges up on it top or puff up on it top.Or tries websites like, to buy and replaced the whole refurbish power supply board.
May 28, 2010 | Hitachi 32PD5200 32 in. HD-Ready Plasma...
I have a Samsung flat panel television, model #LN-T4042H. When I turn the tv on, it sounds like it is turning itself off and on repeatedly for more than 5 minutes before I finally hear the beeps that...
Take ur tv aparts.The power supply board is the board that ur power A/C power cord go into it.U know basic electronic.U have soldering iron,know soldering,and solders?Check all around the power supply board.Look all around the power supply board,check and see find any defective gases leakage capacitors.These dead capacitors alway have bulges or fuff up it top.Replaced these dead gases lekage capacitors will solved ur power problems.Or tries Websites like, to buy a whole refurbish power supply board for the replacement.
May 11, 2010 | Samsung LN-T4042H 40 in. LCD HDTV
Audiovox FPE3705 37 inches is having no reaction to electricity and power.
Ur power board is dead.Must take the tv aparts.Check the power board for dead capacitors like puff up or burst open capcitors.Replaced these capacitors to get power back.U know how to solders right?Or tries, to buy refurbish power board.
Jan 11, 2010 | Audiovox FPE3705 37 in. HDTV-Ready LCD...
Instrument cluster dead
If your replacement cluster is a used cluster, it might have the same problem, which usually is bad solder points where the main connector connects onto the circuit board of the cluster. If you do some internet searches under Caravan instrument cluster solder you should get lots of sources for instructions and photos of the problem. Sometimes the bad solder points are NOT really visible to the eye, so it's best to put a drop of solder on every one of the points where the connector attaches to the board. That fixed mine. If your cluster is brand new, I don't know what to tell you.
Apr 04, 2009 | 1996 Dodge Caravan
Mm50 battery dead
If you take out the 8 screws on the back of the mm50 it comes apart easily. The one 18650 rechargeable battery is held in by two screws and 1 connection on the circuit board. Pull the connector out and unsolder all leads. Solder in a new 18650 battery in its place and put it all back together. OR.. For MORE power... Solder in an extra 18650 battery in parallel with the original. DO NOT forget to solder back in the Protection Circuit Module that is in place there... Or you can order another one from a place alike
Rick Kirby
Aug 11, 2008 | Audio Players & Recorders
Broken screen of ipaq 6315
Try this place. They also show you how to tell if your LCD is broken, or just the touchscreen. If you're good with electronics, you could also buy a dead 6315 from e-bay. one that has a good screen, and do the replacement. Good luck
May 09, 2006 | HP iPAQ h6315/h6365 Pocket PC
HP iPAQ h6315/h6365 Pocket PC Logo
110 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
