Question about Dryers
Indesit conden dryer is70c
Heater not workin had prob before cant remem ow to fix can help please,,,,,,,,,,,,,,,thanks dave
  • morpheus666 Apr 24, 2008
    the light is on that says my driers condenser tray is full, I've cleaned the condenser and the tray is deffinitely empty, the heater will not function either?????? any ideas?
    does the condenser light come on when the thermostat has failed?
    regards
    morpheus
  • 16 Answers
Dave - This is usually the thermostats in the back - check these first
Posted on Mar 22, 2008
How do i find thermal switch to reset it
Thermal cut-outs or thermal overloads are normally located inside appliance to the rear next too or around heater and best to get an engineer to help with this problem, only ones I know with switch outside are Whirlpool, WhiteKnight and some old Bosch Dryers.
cdad2d90-7d01-4338-b8f7-af8459600cb3.jpg f3c8c869-e858-4dac-a6e8-039b450bbdef.jpg
Mar 30, 2014 | Indesit IS70C Electric Dryer
Make a lot of nosie
Hi mervyn2011
Sounds like you have a bearing problem or drum roller/slide problems.
You will need to take the dryer apart to determine which problem it is.
For an owners manual go to the following webpage
Please take time to rate me
Bud
http://www.indesit.co.uk/indesit/_pdf/manuals/19504260005_UK.pdf
For parts go to the following webpage.
http://www.ransomspares.co.uk/parts/brands/indesit/tumble-dryers/is70c/
Oct 16, 2012 | Indesit IS70C Electric Dryer
Why does my indesit is70c rattle when spining
the front or back wheel has gone they are plastic
Jun 28, 2012 | Indesit IS70C Electric Dryer
The light on the water drawer of my IS70C dryer is staying on and the dryer isnt drying.
Thank you for the direct question but unfortunately we don't work on Indesit units and have no documentation on them, so I am unable to help you.
Sep 03, 2011 | Indesit IS70C Electric Dryer
Hi,my indesit IS70C tumble drier works but does not heat up.\possible causes please.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Indesit IS70C Electric Dryer
How can i fix my indesit is70c tumble dryer? my indesit is70c tumble dryer wont heat up during performance
open the back panel , not the the full back just the smaller panel located near the bottom half.
the termo will be screwed onto this panel . unscrew and you will see two circles near the top one will have a small pin hole in it . stick a pin in till you hear a click replace and should work fine
Mar 05, 2010 | Dryers
My Indesit IS70C is only blowing cold air. It was fine this morning. Do we have to remove the silver back to get to the thermostat?
Remove the lower rear panel, there you will see the heater element and thermostats, make sure the heater is o/k, and replace both stats.
Plz rate my solution
Thanks.
Dec 18, 2008 | Dryers
Indesit dryer IS70CS
sounds like the heating element or thermostat has gone in the dryer these parts can be bought from www.indesitservice.co.uk or www.espares.co.uk
Aug 02, 2008 | Zanussi TC180W Electric Portable Dryer
Indesit is70c dryer is not heating?
Take off the back plate of the drier to expose heating elements. There you will find two thermo switches, one with a hole in the middle of it. Push something like a pin into this hole until you hear a click. Re assemble back plate and it should work now
Feb 28, 2008 | Dryers
Dryers Logo
145 people viewed this question
Top Dryers Experts
