Question about Sony Playstation 3 (PS3) Console
Ps3 problems my playstation 3 turns on but does not load up the dashboard
  • 1 more comment
  • daviorb37ss8 Jan 27, 2009
  • chazzer_01 Jan 27, 2009
    i did what you said and still isnt working any other ideas and what do you think i should
    it starts up and even if i hold in ps3 button on the conroller it dosent do anything
    i have taken all disks out and tryed everything :(
  • Anonymous Jan 27, 2009
    I got that same **** right now i think. i can turn it on but i cant get any icons to come up. its just a fucken wavy background with no fucken icons. the controller just blinks the whole time. tried unpluggin, restartin, and holdin down the restart button.
  • 32 Answers
Make sure all disks are ejected first. Try holding down the power button on the front near where you put disks in. Keep it held down until it beeps a second time (5-10 seconds after the initial/first beep). Get updated to version 2.2 (came out last night). Good luck!!
Posted on Mar 25, 2008
Sony repair service centers
I would guess your disc drive is failing as that is exactly what happened to me before mine failed :( Sorry for the bad news.
Sep 08, 2014 | Sony Playstation 3 (PS3) Console
My Ps3 wont load the dashboard help
Please try the following solution to fix your PS3. Please note, option 5 will erase your hard drive so any save games you had will be lost.
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 3 "Restore File System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. If it still does not work try the above but choose option 4. If that does not work try option 5 as a last resort, this will erase the hard drive.
Once you have completed the above, the Playstation 3 should restart and spring back to life again!
I hope this helps all of those out there who are suffering this problem.
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
My playstation turns on then turns off and a red light just flashes
There is a possibility that your PS3 is going BAD. If it's still under warranty I would suggest call Sony and have them replace it.If it's under under warranty try taking the HDD off the PS3 (follow the manual). Once it's out, turn on the PS3 and if it's turn on and shows you the dashboard, then your HDD is bad. If not then it's your PS3 system. There are still fix for this but you need to take this to your local PS3 technican.
May 12, 2010 | Sony Playstation 3 (PS3) Console
My PS3 will not load any games. What can I do?
I had a similar problem. My PS3 did not load the disk based games. It just showed the circle for some seconds in the upper right corner and nothing happend. Those disk based games were not visible in the game menu.
I did not have problems with the normal movie DVDs or movie Blu Rays. Those were working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont load game circle is there that shows that it is loading but it never loads
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
Jun 18, 2009 | Sony Playstation 3 (PS3) Console
Will not load games
I had a similar problem. My PS3 did not load the disk based games. Those disk based games were not visible in the game menu.
Jun 14, 2009 | Sony Playstation 3 (PS3) Console
Playstation3 is not loading games at all
I had a similar problem. My PS3 did not load the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
Jun 08, 2009 | Sony Playstation 3 (PS3) Console
Will not load games
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont load games up
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
Nov 18, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 wont play PS3 Games
Im pretty sure you need to replace the laser
Nov 17, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
74 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
