Question about Hitachi 42HDT79 42 in. Plasma Television
Only receives 13 channels
After 1 yr. of flawless service, my Hitachi 42HDT79 now only recognizes 13 Air channels. I cannot set it to Air/Cable any longer. Any suggestions?
    Sergeant:
  • 395 Answers
Try unpluging the set for a few minutes then re-do the auto search if that does'nt help upgade the software.call hitachi for this upgrade.
Posted on Mar 21, 2008
Hitachi 42hdt79 plasma
I have same problem. waiting for help from brother to take off wall and check capacitors....
Some one said replace the main digital board...$400 via the net ...labor and maybe programming??
at least $800...let me know if you got any soloutions allthebette@sbcglobal.net
Jun 14, 2009 | Hitachi 42HDT79 42 in. Plasma Television
Turned on set....screen all black except a dark blue rectangle in center which reads:Failed to receive broadcast [E202]
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
May 22, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
We are receiving channels 1-13 only; don't know how to add more
make sure you have your tv set to cable, if you have a set top box unplug the box plug it back in reboot it, like i said make sure your tv is set to cable then do auto channel scan should work good luck!!
Apr 12, 2009 | Toshiba MD20Q41 20 in. TV/DVD Combo
Channel numbers above 13 do not come in. This started after a power failure. All numbers are received on another TV at that site. How do I program the stations that should be received?
Go into the TV's setup screen and set the tuning mode for "cable" or "CATV". It got set back to "air" after the power failure. When set for off-air tuning, only channels 2 through 13 tune properly. Set for cable and rescan channels and you'll be set.
Apr 07, 2009 | Televison & Video
TRutech 15" LCD does not pick up all channels
Check your TV settings and make sure your tuning is set for cable (may say "cable" or "CATV"). Right now you'll probably find it set for "air". If the TV is set to tune off-the-air, cable channels 2 through 13 work normally, but above that they aren't detected. Once you set the tuning mode to cable, rescan channels and you should have them all.
Apr 01, 2009 | TruTech PLV1615T 15 in. LCD Television
Connecting Hitachi VCR to my Direct TV.
Connect your Direct TV to the Ant. In connection on your VCR. When you want to watch TV, just tune the TV to channel 3 (or whatever channel the Receiver is set for). When you wish to record, set your VCR to that same channel and set your TV to the channel that your VCR outputs to. For simplicity sake, I would suggest setting both systems to channel 3 and just watching your program through the VCR. If you are still using an "off air" antenna, then connect that antenna to the ANT. IN connection on your Direct TV receiver and when you turn off the dish, it will pass the signal through just like the VCR would.
Jan 28, 2009 | Hitachi VTF392A VCR
MORE channels! for CHANNEL SET UP PHILLIPS pl9127 c101/ 27f 800 7583
I need more channels. I ONLY get 13 channels, 1-13. I know im supposed to have more... Phillips Consumer electronis: manufacture no# 3210t127a
Oct 28, 2008 | Philips TS2746C TV
Missing Close Captioning in analog Sony Trinitron
Make sure the CC is not just turned on but in the menu make sure it is set to caption 1.
Jun 20, 2008 | Hitachi 42HDT79 42 in. Plasma Television
No UHF channels
Sorry, looking up the Phillips PTV100, it does not support over the air broadcasting. Supports, cable and satellite reception.
The reason you are picking up The VHF channels (2-13) is they match cable channel frequencies up to this point. The UHF frequencies are not the same as the cable frequencies, even though the channel numbers seem the same.
Some other models or brands of TIVO may have this ability.
Feb 12, 2008 | Philips PTV100
Need help viewing all public television channels
Your TV is set for standard broadcast. You need to go to the set up menu and change from antenna/normal to cable mode. In standard broadcast mode you receive off the air programs 2-13 vhf and 14-83 uhf. In the cable you receive 2-13 and cable channels 14 -125 if the set is not too old. When cable channels first came out some sets would just cover 14- 36 or 14- 47 or 14-66 etc. The newer sets cover the now standard cable channels 14-125. Hope this helps you Stargazer
May 25, 2007 | Quasar SP-2725 27" TV
Hitachi 42HDT79 42 in. Plasma Television Logo
87 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
