Question about Garmin StreetPilot C330 GPS Receiver
Street Pilot problem
I have the same problem you posted in January. Did you ever get your Street Pilot to acquire satellites? Mine ran fine for two months, then one day it refused to acquire statellites. It asks the standard questions but then goes back to that same page and won't acquire satellites.
What's with that?
Bob
  • 4 more comments
  • jndietz Mar 29, 2008
    Worked like a charm for about 6 months, now it is very erratic.  It cannot keep a consistent lock on the satellites.  It continuously has to re-acquire the satellites.
  • Anonymous Apr 04, 2008
    same trouble aquiring sat's.
  • adunlop Apr 06, 2008
    I have to wait for it to keep aquiring satelites Any solutions to improve this in the UK
  • Icemanfan17 Apr 13, 2008
    I am having the same "acquiring satellites" problem. Is there anything I can do?
  • Domerock Apr 23, 2008
    I have the same problem. Worked fine for about 6-mos, now it cannot acquire the satellite signal. I am in the same local area where it worked fine for those 6-mos. Northern California area. I see that this seems to be a more common problem throughout.
  • Anonymous Apr 28, 2008
    I am having the same problem, I tried to load new maps and now it will not acquire a satellite signal. Thanks
Having the same problem. Worked great for a year, and then couldn't connect once, and now never connects. I can never find any satellite and as such is pretty worthless.
Posted on Apr 19, 2008
SOURCE:
Fails to acquire satellites. Garmin 310
I'm assuming you mean a Street Pilot c310. If so, here is the link to the unit software from Garmin. Download it and follow the directions. Once you connect your GPS, it will update the device software are hopefully should fix the problem with it acquiring satellites.
Nov 08, 2009 | Garmin GPS
Battery replacement now ca't find satellite Garmin c320
More than likely when you reinstalled the gps receiver (the board with the wires connected to it) at the top of the receiver you did not position it properly. If it is not positioned properly it will not receive a satellite signal
May 06, 2009 | Garmin StreetPilot C320 (010-00401-00) GPS...
Touch screen dos not work on garmin GPS street pilot 7200
Try resetting the unit by using a ball point pen or other sharp thing and press it for more than 10 seconds. It would be on the left/right/back side of your unit.
Also, try to hold your finger on the power key for approximately 15 seconds until you see a message "This operation will erase all waypoints, do you want to continue?"
Tap yes and the unit should reboot then attempt to acquire satellites. You will lose any favorites you have saved but it may save you a trip to the factory.
Please ask for further clarifications.
Please rate this solution as FixYa if found useful.
Thanks
Rylee
Mar 08, 2009 | GPS
I had the same issue with the only difference that I haven't replaced the battery yet. When my unit can't locate or acquire satellites I change between GPS and WAAS mode. Within 45 seconds my unit successfully locates satellite. After some time if I disconnect unit I might have to switch it back to GPS and so on, and so on, and so on. It worked for me for past 3 months... Hope it will help you...
Nov 12, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
My Garmin c330 has difficulty acquiring satellites in my new 2009 Camry XLE. Does it have something to do with Bluetooth? Does it interfere? Ever since we bought the 2009 Camry XLE in June, the Street...
The C330 does not have bluetooth capability. Regardless, this has nothing to do with the unit's ability to acquire satellites. Nor should the type of vehicle you purchased, unless the unit is unable to receive due to some feature, like something in the windshield, which is preventing the unit from receiving a proper signal. Does the unit work outside the vehicle?
Aug 02, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin GPS GSMAP 182C Chartplotter will not boot up
If the unit doesn't go further from the reading card. this may indicate that theres a problem in the memory card.
Not being able to a get a signal lock on satellites would indicate a problem either in the software something is wrong or not geting loaded correctly (the memory card) Or a hardware problem.
You may have to take it in for service if you are unable to check the memory card or replace it.
Jun 27, 2008 | Garmin eTrex GPS Receiver
My Garmin street pilot 3i has stopped receiving satellite reception. It started about a week ago. Since then I've been on the Garmin site and checked for updates, changed the batteries and done a full...
Question: Why won't my StreetPilot i-series device acquire satellites?
Same happened to me - try --> Answer: If your StreetPilot i-series unit is having a hard time acquiring satellites we would recommend ensuring that it currently has the most recent version of unit software and then performing a master reset. In order to update your unit to the current version of software you will need to use the Garmin WebUpdater. Here is a link to the page on our website that has the WebUpdater program and instructions on how to use it:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Once your unit has the most up-to-date software, you may need to perform a master reset. To do this follow the steps below:
  1. Start with the device turned off.
  2. Press and hold the arrow button, wheel, and power button simultaneously.
  3. Continue holding these buttons until you see the message, “Do you really want to erase all user data?”
  4. Once this message appears, release all three buttons.
  5. Select ‘Yes’
Note: A master reset will restore your unit to the factory defaults and will erase all of your favorites and recent selections.
Once you have completed these steps, please place your unit outside in an area where it will have a clear view of the sky. The unit may need 15-20 minutes to initially acquire satellites. Once your unit acquire satellites you may continue normal operation.
solution = solution1description.innerHTML; Last modified on: 02/12/2008
Apr 24, 2008 | Garmin GPS
Wont pickup satellites
WARNING: This will erase ALL user data on the device. You'll have to re-enter your custom addresses, etc...
To erase all user data on the device, please follow these steps:
  1. With the unit turned off press and hold the thumb wheel down, then press the back arrow and hold down, then press the power button.
  2. When all 3 are held down a message will appear that reads "DO YOU REALLY WANT TO ERASE ALL USER DATA". Select "Yes".
  3. Let go of the buttons and go through the reset sequence. The unit will need to sit outside to acquire satellites.
Nov 21, 2007 | Garmin StreetPilot i3 GPS Receiver
Trouble Acquiring Satellites
This can be easily fixed....
I had the same problem, I returned first piece and exchanged for the second. Had the same problem with second and took back to Circuit city. The GPS guys took out 3rd one for me and had same problem. Then the manager came who has been using these for couple of years and tried to set the home location 3 times and it worked 3rd time. He did the same for the second returned piece and it also worked. He says since these pieces are programmed for Kansas we need to give 3-4 tried before the piece first 'locates' satellite and then acquires satellite. After the the piece just turned out to be awesome.
Oct 02, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
197 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
