Question about Euro-Pro 473
The bobbin threader
For some reason my bobbin threader is on and I don't know how to stop it.
  • Anonymous Mar 28, 2014
    bobbin threader quit worling
    Problem Solver:
  • 13 Answers
Push it to the left with your finger, which will move it into the off position.
Posted on Dec 30, 2008
The automatic threader isn't working. the bobbin isn't sewing correctly?
make sure the bobbin is turned counter clock wise, also try changing the bobbin, also try a new needle. you may have to have the automatic needle threader checked to see why it's not working
May 20, 2016 | Singer Inspiration 4206
How do I get the casing off? I can't seem to get the bobbin wider to work and want to check its connection or tire.
There are small plugs with screws behind them. Remove all of them. (Make little numbered tape to attach to each hole and a number to match with the screw for markers to keep them in the right place)
The casing must be separated with a firm pull. They are snapped together.
Sep 28, 2015 | Brother XL-2600
Automatic needle threader stuck
You may have a thread stuck in your bobbin area. Remove your bobbin, brush gently with a clean soft brush to remove dust and/or thread bits, then gently wiggle your hand wheel back and forth, and brush again. This should free up your machine.
Jul 09, 2014 | Janome Sewist 500 Sewing Machine
I just bought a used Husqvarna Viking Designer I, and although the item was described as being "in perfect working order," the bobbin doesn't wind properly. The bobbin stop doesn't slide...
If you go to your local jo-ann's or hancock, they generally have a technition who comes in once a week our so to fix machines. A tune-up will generally run between $60-100, and thay should help your above mentioned problem, as well as keep everything else in tio-top shape. If there were, by slim chance, to be any additional costs associated with such a repair, the repair person will tell you ahead of time. Congrats on your new purchase!
Jun 22, 2011 | Husqvarna Designer I
How do i thread a bobbin?
Start by putting the thread from inside the bobbin out the little hole then put this bobbin on the bobbin threader spool on your machine, push it into gear, and press the foot until it stops or looks full. hope this helps.
Feb 08, 2010 | Singer 8280 Mechanical Sewing Machine
Bobbin won't wind the thread
open the machine there is a wrong black rubber that need to be replaced
Aug 02, 2009 | Sewing Machines
How do i thread my bobbin on my singer merritt 4530
Run the thread around the little silver knob on the top of the machine to the bobbin threader on the top right. Wrap the thread clockwise around the bobbin a few times and then pull the bobbin threader toward the silver bar. If you put your hand on the crank wheel, you will feel a place for your finger to set. Push there and the center of the crank wheel will sideways allowing you to thread the bobbin when you press the pedal. I'm sure my terminology doesn't make any sense.
Jul 11, 2009 | Singer 7462 Mechanical Sewing Machine
Euro-Pro 473 Logo
35 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
