Question about Garmin StreetPilot C330 GPS Receiver
C330 Won't acquire satellites..
My c330 won't acquire any satellites. I was working just fine before. Garmin recommends leaving it on for approx. 45 min. in the car whilst stationary to fix the problem. Didn't work. I tried to reset. Played with all the settings features. Entered different destinations. I drove around with it for a whole day, and still nothing. What is up with this? Same problem. The c330 worked fine in the car for about 2 months. Now when it turns on it works through the normal pages to the "Aquiring Satellites" page and goes no further, no matter how long I leave it turned on.
Bob
  • Anonymous Apr 01, 2014
    mymgarmin will ask if I'm indoors,united states and the day of week. I give the correct answers and it will not navigate, it just reads acquiring satellites. I tried turning it off and restarting again . I also did the reset button and no results. it says it is fully charged.
    Guru:
  • 1,894 Answers
Please do a firmware update sir
Posted on Mar 21, 2008
  • 2 more comments
  • dewan nafees ahmed Mar 21, 2008
    have you checked the chipset software (menu->system->menu
    button->software option).
    if The chipset software version was set to
    0.00 which means that the firmware update erased the chipset data.
    get the chipset data manually from the Garmin website and it fixes your
    problems.
    1. Click on the link below and click "GPSMAP60CSx_360.exe".
    Choose to save the file to your computer.
    http://www.gpsinformation.org/perry/gps6...
    2. Choose a location where you can easily locate the file by saving it to a location such as the "My Documents" or Desktop.
    3. Once the download is complete, locate the file and double-click on it. This will launch the Win-Zip Self Extractor.
    4. Click on the button labeled "Un-zip".
    5. Once the un-zip process is complete, click on the "Close" button to exit the Win-Zip Self Extractor.
    6. Open the C:\Garmin folder locate the file named 'Updater' and double click on it.
    7.
    You should see the name of your GPS device next to the 'USB Device'
    option on the Updater program window. Select the 'USB Device' option,
    then click on 'OK' on the Updater program window to start the data
    transfer.
    8. Once this is complete the unit's operating system will be update to the current version.
    Hold onto the power button and push in and release the reset button on
    back and when the power logo comes up you release the start button.
    Another reset for the satalite aquisition is to push and hold the push
    in button on side and then push the reset button and release still
    holding the side button in until the power logo comes up and that will
    reset your satalite reception. Good luck.
    nstructions for a hard reset:
    Hold down the power button, while holding, use the reset tool and on
    the back press gently and release the reset button, when the Palm logo
    appears, release the Power button.
    if nothing helps then your antenna is dead.
    you will have to change it sir.
    thank you
    good luck
SOURCE:
My garmin street pilot c330 won't aquire satillite. this unit is 2 years old, but never out of the box. i got it from my son and tried to set up. when you turn it on all of the data in the unit is...
Try connecting in your car and leave it on and let it charge while you are driving it may eventually find the satellite, it probably remembers the last satellite it found which was in Kansas. You may not be getting a signal where your are right now so run some errands and leave it connected in your car.
You can also go to the garmin web site and try updating the unit. You will need a usb cable and will need to install garmin updater. Make sure the unit is fully charged.
If this does not work you can call garmin and they are usually very helpful. Here is the garmin link which will help answer some more questions.
http://www.garmin.com/garmin/cms/site/us/support/
Let me know what solved the problem. thanks for using fixya
May 14, 2011 | Garmin StreetPilot C330 GPS Receiver
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Regards
Richard.
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
GARMINC330
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
Link for updating firmware select your model
hope this helps .
Mar 08, 2009 | Garmin StreetPilot C330 GPS Receiver
My Garmin c330 has difficulty acquiring satellites in my new 2009 Camry XLE. Does it have something to do with Bluetooth? Does it interfere? Ever since we bought the 2009 Camry XLE in June, the Street...
The C330 does not have bluetooth capability. Regardless, this has nothing to do with the unit's ability to acquire satellites. Nor should the type of vehicle you purchased, unless the unit is unable to receive due to some feature, like something in the windshield, which is preventing the unit from receiving a proper signal. Does the unit work outside the vehicle?
Aug 02, 2008 | Garmin StreetPilot C330 GPS Receiver
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Street Pilot problem
Having the same problem. Worked great for a year, and then couldn't connect once, and now never connects. I can never find any satellite and as such is pretty worthless.
Mar 21, 2008 | Garmin StreetPilot C330 GPS Receiver
Aquiring satellites
Are you outside with a clear view of the sky? It should find satellites once the unit is turned on. Does it say "Looking for satellites" or "Acquiring satellites"?
If it is "looking for satellites" then it means that the unit have lost all data (time, date, location). If it is "acquiring satellites" then it have date and time, but not location.
Looking for satellites require a longer setup time (could be as much as 15 minutes). Acquiring satellites is much faster (not more than 2 minutes).
Date and time is updated from satellites once the unit gets a satellite lock.
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
When Mine did that I bought an external antennea and now it works great
Jan 20, 2008 | Garmin StreetPilot C330 GPS Receiver
No signal
Try and replace the antenna
Aug 11, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
198 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
