Question about Philips Magnavox MWR10D6 DVD Recorder
MAGNAVOX MWR10D6 I recorded a show, but I am not able to watch it in another DVD player... how can I watch it in any DVD player? does the REC Mode has anything to do with it?
  • 476 Answers
You need to finalise the disc before it will play in a DVD player (DVD+-R), or make edits compatible (DVD+-RW)
Check out the "Playing the discs in other DVD players" section in the "Recording" chapter of the manual. (Page 36)
If you don't have the manual, it can be downloaded from this link
http://www.funai-corp.com/6pdf/om/MWR10D6.pdf
Posted on Mar 21, 2008
6ya staff
SOURCE:
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I forget the exact steps for the remote to record from my video camera to dvd recorder
You have to plug the video cam into the front ports of the Magnavox.
Then press the Setup Button
Go to Required Settings --> OK
Video Input --> OK
Go to E2 --> make sure it says "video in," unless you are using an S-Video connector --> OK
Press Setup
Start playing from Camcorder and make sure that you can see the picture on your TV screen.
Press REC on the Magnavox
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Can't record tv shows
I'm afraid that the manual for this unit is a little dense.
Now that the digital conversion is imminent, nothing will ever be simple again.
This is not the ONLY way to record with this machine, but here is one way: (I'm also assuming that you have a cable or satellite BOX - if you don't, let me know):
1. Connect a red, white, and yellow cable from a red/white/yellow OUT of your cable or satellite box to the Video IN and Audio IN of the Magnavox.
2. Connect a second red, white, and yellow cable from the Video and Audio OUT of the Magnavox to a red/white/yellow IN of your TV (most TV's only have INs and not OUTs, hence they may be unmarked either way - but this situation is rapidly changing).
3. Change your TV to the channel that corresponds to the red/white/yellow port - some TV's label it "AV1," "AV2" etc. - others label it "Video1", "Aux 1" etc. - I would have to know the exact model # of your TV to be sure.
4. As long as you can see the channel that you are trying to record on the TV screen, you can just press REC on the Magnavox with a blank DVD inserted.
Like I said, this is not the ONLY way, but it is probably the simplest.
-Tha Mp3 Doctor
Jan 27, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I am trying to record from my dvr to my magnavox 10d6 recorder
Connect the yellow/red/white out from the VCR to the same inputs on the 2160. Press setup. select general. select video select video input. select L1 or L2. press ok. select video or s-video.
press setup to exit.
select HDD or DVD (whichever you want to record to)
use source or channel to select L1 or L2
press rec mode to select sp/lp/ep/etc
press record to start recording
start playback on the input device
press stop to stop recording.
The manual is available as a PDF file on the web. It would save a lot of typing...
tom
Jan 20, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I HAVE A MAGNAVOX DVD RECORDER MWR10D6 AND I AM TRYING TO RECORD VHS TAPE FROM A VCR TO THE DVD RECORDER. CAN YOU HELP ME WITH THE CORRECT CORRECTIONS; NOTHING IS RECORDING
Play the video on your through your recorder if possible, then record it that way. It works for me. Just go to your watch tv setting and record it off channel three while the vcr plays the video.
Jan 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I need a manual for Magnavox dvd/ recorder for MWR10D6
Although this is a Magnavox DVR, it is made by Funai. The manual for it can be found at:
Hope this helps!
Jan 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Is a Magnavox MWR10D6 DVD Recorder codec or driver needed to play DVD disks on computer?
There are work arounds... but the reason is when its burnt and finialized its written in .vob format which is dvd mpeg2 format. majority of windows media player codecs wont pick it up. divx does. its just the format its burnt in and you cant change obviously. you can just try like nero showtime which always works or ending up ripping the disc on the computier but that might defeat your purpost of burning them in the first place. Its not the dvd recorder i may add, its just the format. by the way its a magnavox unit made by funai... www.funai-corp.com/support and trust me your not going to get much out of their. your better off going into forums finding more high depth problems if you really want this to work for firends and families and such.
Oct 22, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Cannot record in +VR mode
check to see if the U-verse box is in HD mode. If it is, change it to standard definition and the problem should be solved.
Menu -> Options -> System Settings -> Aspect Ratio
Sep 28, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Brain fade
The manual is located at: www.funai-corp.com/6pdf/om/MWR10D6.pdf (copy and paste in your address bar) it shows some helpful connection scenarios...hope this helps!
Jun 02, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Black pic on tv fm dvd rec
Several possibilities. If there is a HD box going into this unit, it will give you this message. If there is a modulator or converter box between the cable/sat box and this unit, it will give you that msg. If you have an input plugged into an input, it will give you this msg. Finally, if you have anything other than a camcorder plugged into the FRONT of this unit, it will give you this message. Recheck your connections.
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox MWR10D6 DVD Recorder Logo
134 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
