Question about HP PSC1510 Printer/Scanner/Copier (PSC1510)
Scanned documents are very light
How do i darken my scanned documents or even my regular print copies?
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
Posted on Jan 30, 2009
Is it possible to darken colors when printing a copy
You can usually can only alter or darken a print colour from the software program (i.e. Word), then send your document to the printer.
Feb 11, 2014 | HP Officejet 6500A Plus Wireless...
My scanned pages are too light.
Try to use the Lexmark All-In-One Center Application on your computer to adjust the darkness of your prints. On your computer, click on Start > Prorgrams > Lexmark 2600 Series folder > select All-In-One Center. From the Copy tab, select "darken" copies.
For printing, Normal or Best mode in the Print Setup properties before sending the print job to the printer for printing.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 19, 2011 | Lexmark X2600 InkJet Printer
All of my copies and scans have a yellow background. This does not happen when I print a document directly.
You might be scanning and copying in full color even for regular documents. When you do this, it treats the document as a photograph or color document and therefore, the background, even if white, is scanned in as a bit yellow
Feb 28, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Exposure problem
If internally generated prints are good, but copied documents are bad then your scanner needs cleaning. This can be found in the document feeder section where the light scans across the paper. If both copied and internally generated prints are bad, then chance are, your toner/drum catridge has run out.
Jun 18, 2010 | Canon D320 imageCLASS Digital Copier
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I want to copy a document
How often do you need to "copy" documents. Do you have a document scanner?  Your Epson is a printer.  You'll need a scanner to scan a document into your PC then you can print it out on your Epson.  If you only need a copy once in a blue moon, and you don't have a scanner, save yourself a few bucks and just go to Kinko's or maybe even your local grocery store or library and run your copies there.  They probably cost about 25 cents a page.  A new scanner will run you about $100 bucks.  If you decide that you need a scanner, you might even want to consider investing in a multi function printer which will scan-print-copy-fax.  Hope this helps.  If so, please remember to rate my solution.  Thanks.
Mar 14, 2009 | Epson Stylus Color 600 InkJet Printer
Prints beautifully from a scanned copy, but light when copying
Check your copy option,constrast to high and quility to Auto.
after that should be fine.
Feb 09, 2009 | Brother MFC-7420 Printer
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
2,110 people viewed this question
Ben Johnson
