Question about Zebra 105SL Thermal Label Printer
Rewinder how can I adjust the rewinder from winding labels too tight
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 58 Answers
Go to Zebra's website and get the user guide....
Posted on Mar 25, 2008
When I rewind my boobin, the thread is too loose. How do I adjust it on a JUKI DNU 1541-S?
You're saying the thread on the bobbin is loose/sloppy? That would be a result of the tension placed on the bobbin during winding. Make sure you are using the correct threadpath to wind the bobbin, or the winding tension needs to be adjusted.
https://www.sewingpartsonline.com/juki-dnu-1541-parts.aspx
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwiikseM2J3XAhUE72MKHSV2Bg8QFggmMAA&url=http%3A%2F%2Fdanreetz.com%2Fjuki%2FJUKI_DNU-1541-S-7EM01_SERVICE_MANUAL.pdf&usg=AOvVaw250Npk5Blb-ZBGHGIFqwyy
https://www.manualslib.com/products/Juki-Dnu-1541s-3329212.html
Nov 01, 2017 | Juki Sewing Machines
How to install pull cord?
take off cap then take out old pull cord once done get a cord long enough some will hanging out when recoil rewinds rope next there is hole in rewind pulley make sure you find it then hard part rewind spring on recoil till it stop hold tight the unwind 2 winds hold on tight next slip cord trough houseing and through pull hole put screw driver threw holes in threw rehousing that will hold in place the pulley not the cord take a lighter heat the cord up this will keep the knot in place grab cord remove screw driver from houseing hold cord tight pull cord until knot is seated next two pulley slowly let reciol wind rope in until it stops should be cord hanging out grab hiold of cord next to recoil hole pull out for two pulley revolution hold there install handle on rope tie knot heat knot with lighter your done cut off excess rope reinstall cap and completey down let me no if you have problem i will help im the red neck i like helping people
Aug 28, 2014 | Garden
Adjusting Datamax i class
If the ribbon is moving right on the I-4208 so far that you aren't getting print on the left of your label, the typical solution is to make sure that your ribbon roll is pushed all the way in, as far as it will go (at the top center of the printer on the black hub where the ribbon and it's cardboard core slide on). Similarly, make sure that the used ribbon that is winding on to the Rewind Hub at the top front is also in (to the left) as far as it will go).
Jun 26, 2014 | Datamax DMX-I-4208 Label Printer
Replace pull cord
Echo is one of the easiest pull cords to fix, remove the screws on the rewind and take off the motor and flip it over and pull old rope out and put new rope in wind the spring the correct way so when you pull rope it tightens spring so it will wind back up when let go, not winding too tight !
May 22, 2013 | Echo Pb - 413t Backpack Blower
The bobbins doesn't wind easily and tight
When winding the bobbin, go slower not faster. And make sure that you have it threaded right, follow the diagram carefully with the thread unwinding from the spool the right way. You can take your tight bobbin off and use that as your spool and rewind onto a fresh bobbin. You cannot be a "speedy gonzalez" and have it be even.
Mar 01, 2011 | Singer 3116 Simple
The rewind spring for the pull start came out. What is the trick to rewind it???
put the housing end in first, take the spool and hold the spool end against it and wind the spool in the air until the spring is wound tight, then install the spool back into the housing. you have to keep your fingers on each end of the spring and hold the spool relatively close to the housing, obviously, but it's not a hard trick to master.
Sep 06, 2010 | Stihl Garden
How to you re tension the starter spring
What has to be done is the BLOWER Housing must be removed from the engine. Then pull the rope all the way out, NOTE which way it is turning. Then stick a screw driver thru the spokes on the wheel and straight thru the housing, this will keep the rewinder from rewinding.
Then cut the knot from the cord. Remove the cord. Engage the rewinder wheel with your fingers pull the screwdriver and wind the spring as tight as you can. Re-install the screw driver thru the wheel so it can not rewind and reinstall the cord. When tying the knot ,make sure to use a light to melt the cord a little so the knot will not untie.
Hold the handle tight and pull the screwdriver and slowly let the spring wind in the cord.
Done
Oct 20, 2009 | Garden
Bobbin does not wind all the way up
I have had this problem, easily fixed by twisting the rubber knob that is in contact with the spool to the left.
Feb 08, 2009 | Husqvarna Lily 540 and 550
Film wont rewind
nadyne,
manual rewind is next to lcd panel right side. hold the button down for 3sec. the re-wind symbol will be displayed on the lcd panel.while holding down the re-wind button depress the shutter button. film will re-wind.
Dec 15, 2008 | Pentax IQZoom 928 35mm Point and Shoot...
Labels slightly shifting causing issues
I have had this problem before, if you look behind the rewind plate there are two nuts one on either side, if you undo these and adjust the hight down slightly on the r/h side it should solve the problem.
hope this helps
Dec 10, 2008 | Zebra 170XiIIIPlus Thermal Label Printer
Zebra 105SL Thermal Label Printer Logo
137 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
