Question about Sony KP-65WV700 65" Rear Projection HDTV
Sony kp-65wv700 How do you turn down the screen control for the blue gun for the small blue curved lines ? Thanks for all your help its a good thing your doing for people .
  • Sony Master
  • 8,617 Answers
I sent instructions in my last post to you, if you cant find it let me know and I will pull up the specific model for your set and try to help you locate it. And thanks I enjoy helping people with their sets I have been doing this over 25 years and still enjoy working with electronics.
Posted on Mar 21, 2008
2 Suggested Answers
SOURCE:
Slinteriors
  • 8617 Answers
SOURCE: sony kp-65wv700
take the back off there should be a small rectangle with 6 buttons on it 3 for focus and 3 for the G2 (screens) some models have this control in the front behind the speaker grille behind an access panel and others have the control switch on the circuit board that is attav=ched to the crt neck. Either way its just a small switch much like a volume switch but smaller. Depending on what chassis you have it will be in one of the 3 areas I have mentioned. just turn it down a little. If that doesnt take the lines away you will need to trouble shoot the blue drive circuit.
KP-65WV600 Red and Green Lamps fade out after about 15 seconds
Hi, if the tubes fade from full brilliance to black over a few seconds, the possible sounds like dry joints in the CRT heater circuits. possibly caused by dry joints (bad solder joints). Most repairs involving rear projection TV's can be a pig (mainly relating to access to work on the circuit boards)
Sep 23, 2010 | Sony KP-65WV700 65" Rear Projection HDTV
I get curved red lines and then screen goes completely red and no sound
This is symptom of defective red picture tube in TV that needs to be replaced.
Let me know if you want to replace it by yourself to provide you part number info or call tv tech to do the job.
Thanks.
Nov 30, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
SONY TV MODEL # KP-65WV700 SER.# 9002706
Blue Gun is right side of TV if you look in TV from back side. Part number is as follows..
8-733-663-25 {CRT 07MVC62(B)-L} [KP-65WV700 ONLY]
Mar 13, 2009 | Sony Televison & Video
I have a KP-65WV700 and the screen looks a lil to green
OK, I'm the guy that was having the same problem, but had a blue tint to the screen. I also had blue lines running across the screen, and when I followed the steps below that were posted by another user not only did the lines disappear, but the blue haze vanished as well. My tv looks like it's new again, so you may want to try this:
noavatar_s.gif Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
I have fixed this several times on my KP 65WV700
As Slinteriors posted if it is a thin curved line you need to adjust the screen control, it's sorta like a brightness for each color, and if one color is too high it will produce a thin curved line.
The best way I have found to get to the controls is by removing the lower grey speaker cover front the front of the TV. There are 6 screws if i remember, 3 on each side. Then it snaps off, seems like its going to break but you have to pop it off pretty good.
Once its loose you have to remove a cardboard like cover plate in the center that will give you access to the small controller board.
Now be very careful while experimenting on which knob controls which colors. Turn them very slow, if you turn to fast you will cause your TV to shut down. If this happens, turn the adjustment back to original spot and turn TV back on and take it slow.
Adjust the correct color until the line just goes away. Its easiest to do this with a black screen.
Nov 18, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Kp-65wv700
You need to adjust Green screen drive control your green tube could be shorting out.
Sep 14, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Screen goes off after a few seconds
The red tube is going out. I have the same problem with my Blue tube. If you get rid of your TV I will buy your blue tube.......
Jun 17, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Blue gun control
Remove the front speaker grille and also the smal;l access panel and you will see a small control box with 6 switches 3 control the focous and 3 control the screen control. The screen control will be laid out like the CRTs are Green in the center and blue and red on either side just turn the blue down very little or you will make the CRTs shut down.
May 01, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sony kp-65wv700
Mar 21, 2008 | Televison & Video
Sony kp-65wv700
I followed GuestUser/ Slinteriors advice and I fixed it. Open the front of the TV and there are 6 little nobs in the front. The botton 3 are what you need to adjust. from left to right the color controls are BLUE, RED GREEN. For the blue lines, slightly (I really mean very slightly) turn the botton left nob clockwise (right).
Mar 21, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sony KP-65WV700 65" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
