Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuum lock Vacuum will not go back into upright position. There is resistance as you raise the handle.
  • jtucken Apr 02, 2008
    cannot click into up position
  • Systemagic May 03, 2008
    I've just developed the same problem. The vacuum was purchased new and not very old.
I just solved my own problem. I'm not much of a technical writer and I'm sure I don't know the proper terms but nonetheless...
...When standing behind the vacuum, as if using it, just above the right rear wheel is a detachable elbow for the air flow. The housing next to the wheel, wherein the elbow fits down into, is one segment of the problem the other segment, with which it may have come out of alignment, is the main front cover of the vacuum head. With the vacuum upside down in my lap I simply rolled the two components back into a position so that the front cover slides under the housing instead of bumping into it on top.
I hope this solves your problem too.
Posted on May 03, 2008
Thank you Systemagic. It took me a minute to figure out what you meant until that little elbow thingy came off in my hand, and then I just jiggled a couple of things around and presto...it worked. I never would have found that myself!
Posted on May 14, 2008
My roller ball vacuum will run when the handle is lowered to use the floor vacuum but shuts off when locking the handle in the upright position.
Check the instruction book. Some machines shut off when handle is locked in upright position.
Dec 22, 2017 | Vacuums
How do I change the selector switch
The easiest way is to lock the vacuum in the upright position and then tilt back slightly (raising the drive wheels) slide the carpet / hard floor switch to the desired position.
Sep 18, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
How do I get the vacuum to go back to its upright position after vacuuming
The upright stabiliser is designed to lower and lock into place automatically when you raise the handle. If it doesn't seem to be doing this as usual, please call our Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US) so we can provide further assistance to resolve this.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 24, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Have a DC25, I can not return the handle to the upright position. Nothing appears to be broken
Occasionally, customers have problems locking their Dyson vacuum in the upright position. This is a minor problem common with the Dyson DC07 and DC14 series and can easily be fixed by the customer. This page will show how to fix this problem. Although we show a Dyson DC14 Animal on this page, these instructions will work on any Dyson vacuum in the DC07 and DC14 series.
During shipping, moving parts on a Dyson vacuum can shift in position. One of these parts is a swinging arm in the base of the unit. This arm holds a removable elbow pipe in the vacuum's air passage. This arm can move out of the way so that you can clear out a blockage in the air passage. When this arm is out of position, the vacuum will not lock in the upright position. Fig. 1 Shows the base of a Dyson DC14 Animal locked upright. The red arrow points to the swinging arm. Fig. 2 shows the vacuum with the swing arm out of position. Since the swing arm is lower than it should be, it doesn't line up with the tab on the main body indicated by the red arrow.
Lean the handle of your Dyson all the way back and locate the black button on the right side of the vacuum indicated by the red arrow in Fig. 3.. Press the button down and hold it to unlock the swing arm.
While holding down the black button, pull the swinging arm (Shaded red in Fig. 4) all the way up. Fig. 5 shows the swinging arm in the correct position. Release the black button to lock the swing arm back in place.
The vacuum can now lock in the upright position as shown in Fig. 6. Note how the tab on the swinging arm overlaps the tab on the main body..
dcramer531_17.jpgdcramer531_18.jpgdcramer531_19.jpgdcramer531_20.jpgdcramer531_21.jpgdcramer531_22.jpg
Dec 11, 2010 | Dyson DC25 All Floors Bagless Upright...
Placing the handle of my Dyson DC07 into its upright and locked position causes the beater bar to stop turning. It will not start turning until the handle is first lowered to the working position and the...
Hi its Darran at Dyson.
The brush control is designed to switch the brush bar off automatically when you stand the machine back into the upright position. It is designed this way to protect any delicate floor surfaces when you have the machine switched on and upright and when you are using the hose.
If the brush control should be in the centre position and move forward to the "on" position when you release the head. If it is not doing this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Feb 22, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuum height won't go on low carpet setting. Dial will go on medium and high, but not low.
Make sure you're not trying to adjust w/ handle in upright locked position because thewre is a cam which raises the vacuum head a little bit when handle is locked in upright position. If this is not the problem, turn vacuum upside down with handle in unlocked position and power cord not plugged in(for safety reasons obviously), unscrew and remove 3 screws that hold belt/beater brush assembly cover in place(2 are in corner near ends of beater brush and 1 is towards motor housing) tilt end of cover with 1 screw up and remove cover(there are 2 tabs at beater brush end of cover). Right above this is the height adjustment assembly with 2 rollers, raise up the assembly gently and using your finger or a bristle bottle brush,etc. make sure there is no debris caught between the height assembly and the hose(you will understand when you see it), if there is no debris you can now see the pattern on the bottom of the height adjustment knob and the lobe that rides on it, just check to make sure nothing is broken and/or missing, hope this helps!!
Dec 29, 2009 | Hoover Vacuums
THe vacuum won't divert from hose to carpet
Turn the vacuum off, return the handle to upright locked position.
Then securely fit hose into the hose holder.
Then depress lever and engage handle into non-locked position, and turn on vacuum on "carpet"
There will always be some airflow through the hose, but when the hose is parked it creates more airflow to the carpet head
Dec 22, 2009 | Kenmore Progressive Bagless Upright with...
Dyson 28 handle is stuck in the locked and upright position. Vac runs fine, just can't get the handle to release to run the vac
On the lower right side of the body of this model is a air duct piece that can get stuck and won't allow you to use the release. Take out that piece and put it back on again to see if that will unlock it.
Nov 30, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc07 will not lock into upright position
- Stand behind the vacuum cleaner and look at the right-hand side wheel
- Remove the AI PIPE (it has two purple buttons that you push together to lift it up and out - it looks like a Tuba)
- Lay the handle down and look for a black button that will be exposed in front of the square hole
- Stick your index finger and middle finger into the vacant AI Pipe Hole (the square hole)
- Reach over with your thumb and press the black button in front of the square hole
- Whilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square hole basically)
- Remove your fingers from the square hole
- Lift the handle and stand your machine back upright again
- Place the AI Pipe back into the square hole
Jul 12, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Carpet Height Adjusment
In addition to the tab that contacts the bottom of the slider, there are 2 protusions on the adjustable wheel plate that move through holes in the housing, but only when the handle is tilted to begin vacuuming. The wheel plate has a spring that forces the tab against the slider. As the handle is moved to the upright position, the protusions move back through the holes, taking the tab away from the slider and the wheel plate locks in its highest position. Therefore, the position of the slider has no effect while the handle is upright and locked. Hope this helps.
Aug 19, 2007 | Hoover U5753-900 WindTunnel Bagless...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
80 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
