Question about Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt cd player
My cd player (blaukpunkt) for a mercedes A140 model 2004 can't read copied cds, even a have copied them with x2 speed.what i have to do to solve this problem??
  • 199 Answers
Hi this odel is not CDR compatable.
Blue ICE
Posted on Mar 22, 2008
Copied CDs won't play with my Aiwa LCX 350 shelf system. It will spin for a bit, then stop. I've tried every method ... with or without remote, start/stop, etc. This doesn't happen with any retail CD. Only...
It sounds like it's not reading the CD. 2 things to try, neither of which are guaranteed to work:
1) Try changing the brand/colour of your recordable CD.  Some machines read different colours/brands better than others; particularly older CD players.  If the ones you have are all light-coloured, try burning a couple of dark-coloured CDs and see if that helps
2) It could be the speed at which you're recording.  Try burning a CD at 1x speed and see if that helps.
May 26, 2010 | Aiwa Audio Players & Recorders
Mercedes A140 gearbox fault
Its a common and known fault on the Mercedes A140 unfortunately. Mercedes seem to have rectifieded the issue on later A series models but to my knowledge they have never admitted to a problem or had a recall on affected gearboxes.
It is unlikely therefore that you will get much joy from the dealers on this issue. Your best bet might be to source a replacement gearbox from a breakers or even better a reconditioned box with a warranty.
Thanks for using FixYa.
Jan 28, 2010 | 2003 Mercedes-Benz C-Class
Wont read some discs
People need to learn to leave more info if they want proper help!
What type of discs? You say some, are they CD-R, CD-RW, SACD, CD+R, CD+RW, standard store bought Audio CD?
When copying audio cds for playback in other players, always use CD-R to avoid any type of confilcts. CD-R will play in almost any CD player, even from the 80s. Some players say they will support CD-RW, but that is NOT GUARANTEED!
If it is Audio CDs, then the laser may be dirty. If it is MP3 cds or DATA cds, then try only putting one type of file on the disc, such as only MP3s, or only WMAs.
Oct 01, 2009 | Denon DN-S3000 Turntable
I hve a gemini cd 200 and the left deck stopped reading cd's. when i put in a disk the lcd reads no disk. What cuold be the problem.
Just like with any CD player, the optics have lifetimes. Either the optics are dirty and can not read the disk or they have failed. These units use KSS-213 optics assemblies from Sony, if I remember correctly. These can be purchased for around $25. Any one with audio repair experience should be able to replace them for you.
Jul 31, 2009 | Nu Mark Numark CD-Mix-2 Dual CD...
I have bought a 3 audio cd box set for my blaupunkt santa cruz cd player and it wont play any of the discs it just says 'CD ERROR' all other cds work fine.
There is obvioulsy and incompatability problem with the type of CDR that the cd's are and your head unit, Try making a backup copy of the CD's and try them in the player. This should resolve your problem
Jul 11, 2009 | Car Audio & Video
My Blaupunkt Bermuda MP35 not reading the CDs sometimes
are they CDs from a store and legal? or are they copies? cdr? cdrw? cause some players are tempromental with burned CDs.
May 21, 2009 | Blaupunkt Car Audio & Video
I dont know how to use it.
hope this helps
Feb 17, 2009 | Blaupunkt Los Angeles MP72 CD Player
2004 Jetta CD Player Won't Read CD's
I had the same problem when I first got it.  I realized that the problem was the CD I was putting in.  The CD player will NOT read burned RW CDs.  I hope that helps!  But it will read burned R CDs and ones from the store.
Dec 21, 2008 | 2004 Volkswagen Jetta
How do I copy a CD on my denon CDR-W1500
Operating instructios can be downloade here:
About copying
 Copying can be performed easily from the set’s CD unit onto the CD-R unit.
 There are two copying speeds (normal and high) and four copying modes.
• The mode switches as described below each time the normal speed copying button (NORMAL) or the high speed copying
button (HIGH) is pressed.
• The recording level is automatically set to the default value (0.0 dB).
• The repeat and random play modes are canceled when the copy mode is set.
• During normal speed copying you can listen to the sound as you copy.
• During high speed copying no sound is produced.
• No signals are output from the digital outputs during high speed copying.
• During copying, buttons other than the CD or CD-R stop buttons do not function.
• When CD TEXT compatible CDs are copied, the disc names and track names are also copied.
 When copying, switch the relay mode to the normal or dual mode. Copying is not possible in the relay or mix mode.
 For optimum recording, make sure there are no fingerprints, scratches or dust on the signal surface of the source side CD or
the CD-R/RW.
 The auto track function is always activated in the copying mode. It is not possible to assign track numbers manually.
Disc dubbing: In this mode, entire CDs can be copied onto CD-R/RW.
(“All Tr Dubb” is displayed.)
Make CD: In this mode, entire CDs can be copied onto CD-R/RW then finalized automatically.
(“Make CD Dubb” is displayed.)
1TR dubbing: In this mode, single tracks on CDs can be copied.
(“1Tr Dubbing” is displayed.)
Scan REC dubbing: In this mode, the desired tracks can be selected from CDs and copied.
(“Scan Rec Dub” is displayed.)
Jan 14, 2008 | Audio Players & Recorders
Blaupunkt IDC-A09 5-Disc CD Changer Logo
176 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
