Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Dryer when i set the WD63 to dy mode does not dry and i would say does not even heat up as you would expect the clothes to be at last a little warmer than when they went in. any help would be greatful
  • 16 Answers
FIRST - UNPLUG IT!
First check the one shot thermostat - thete are 2 stats on the top of the heater box - it's the one with the staggered connector terminals - then let me know
Posted on Mar 22, 2008
SOURCE:
Hi I have a dryer (Speed Queen) and I took off the front panel and cleaned everything and even in back, When I turn it on, I see the flame, But it does not get hot enough inside to dry the clothes, Is...
Clothes not drying, but dryer runs & heats
1. Defective operating thermostat---test thermostat,, replace if defective
2. Fan or it's pulley loose on shaft--tighten set screw
3. Incorrect heat or timer setting--reset timer
4. Clothes too wet when placed in dryer--wring clothes before putting them in dryer
5. clogged lint screen or duct ( little air motion)---clean
Sep 21, 2011 | Speed Queen AGS68AWF Gas Dryers
My dryer doesnt heat. I checked the voltage, and ran through all the diagnostic tests to try to get an error code. Everything works fine when in the test mode. Figuring that all was well i went back to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 17, 2011 | Kenmore 84072 Electric Dryer
I also have a Kenmore Elite Smartheat quitepak 9 HE4. It takes forever to dry in the Auto modes and it still leaves them damp. However the Manual modes dry great. I suspect the Auto modes has some kind...
if its a condenser dryer for some unknown spastic reason we have come across some where 80% of the settings didn't dry the clothes we then found out this how they were suppose to work (dont ask me why still havnt figured that i think it was something to do with ironing and not needing to use steam because they are already damp yeah i know doesnt really make a whole lotta sense to me eitha), you need to look up what cycles actually do what as i found only manual and 1 other setting actually completely dyed the clothes
Feb 09, 2011 | Kenmore Elite HE4 Electric Dryer
My Bosch dryer never seems to get very warm.It's an Axxis. I've only washed about 10 loads. It seems to take a long time, and when I take the clothes out, they are cool to the touch. Even when I touch the...
There are a few possibilities here:
1. Washer/dryers generally take longer to dry clothes than a stand-alone dryer so if you previously had a stand-alone and are now using a combi, this could be the reason.
2. There are usually at least 2 heat settings on a dryer, so maybe you have it on a cool setting?
3. The last part of a drying cycle (5-10 minutes) is usually cool - even when on a high setting. This helps to reduce creasing and cools metal parts such as zips and buckles for saftey. This could explain why everything feels cool when you remove the clothes.
It's possible your old dryer didn't have the cool final setting and/or it was higher power than your new Bosch and therefore dried the clothes quicker.
If your new machine is taking an eternity and your clothes still aren't properly dry, then there may be a fault with your dryer thermostat which is switching the heating coil/element off at too low a temperature. However, I suspect your problem is related to information I've written above.
It would help to know whether you have an Axxis washer/dryer or just a dryer. If the information above doesn't help you to solve your problem, please post back with details of your machine, including the model number, if possible.
Regards,
BElectric.
Nov 25, 2010 | Bosch Dryers
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Dryer not drying cloths even though it does the full cycle? hotpoint wd63
There are several reasons for this to happen.
  1. Heater element faulty.
  2. Thermostat faulty.
  3. Heater relay faulty.
  4. Blocked condenser.
  5. No cold water going in on drying cycle.
You really need a meter to test the components with, to get the bottom of the problem.
Please rate my solution.
Thanks.
Nov 16, 2009 | Hotpoint Aquarius WD63 Front Load...
LGE59777S Not drying
There is a little sensor that tells the dryer when to heat and when not to heat. that sensor is bad. If you take the back of the dryer off you will see it. It is about the size of a half dollar and has 2 wires that plug into it. While you have it apart make sure that the dryer vent on the back of the dryer is not plugged with lint. Major cause for fires in dryers.
Jan 04, 2009 | LG DLE5977 Electric Dryer
Our LG dryer doesn't get completely hot until the clothes are mostly dry.
heated air enters the dryer at 140 degrees farenheit,
a portion of the heat energy raises the temperature of the water in the clothes.
When the clothes are cold and wet, the difference is large transfer is rapid
a lot of heat transfers to clothes and the exhaust air is damper and colder
As the clothes get warmer and dryer, proprtionally less heat is extracted from the incoming air, and the exhaust air is warmer and dryer.
When the clothes are dry, and at 140 degrees, the same temperature as the incoming air. no heat is removed from the incoming air
the dryer should then stop heating, draw unheated air through the drum and clothes to cool, and reduce wrinkling
then switch off
the dryer appears to be operating correctly
Oct 31, 2008 | Dryers
Drier Motor
Disconnect the vent at the back of the dryer and dry a load unvented to make sure you don't have a clog in the vent line too the outside causing an air flow restriction, if still not drying check and make sure the blower wheel that circulates the heat inside the dryer isn't broken.
Jul 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
63 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
