Kenmore 24032\24036 Top Load Washer Logo
Posted on Apr 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It is a Kenmore 90 series The model number is (small) 110 (bigger next to it) 22902100 serial number: 2219941 type: 111 This was given to me. they said all it needed was a fuel fill sensor... what is that, where do i get one and how do i change it out myself?
Anonymous
Level 3:
President:
  • Master 1,937 Answers
  • Posted on Apr 19, 2010
Anonymous
Master
Level 3:
President:
Answers
1937
Questions
0
Helped
430219
Points
5400
I have no clue what a Fuel Fill Sensor is on a washing machine. HOWEVER,
See the Sears Parts site for your washer with diagrams of all major parts and components.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22902100&pathTaken=partSearch
Also see the Whirlpool / Kenmore Service manual for this type of washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also see the following for how to access the console and remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=fdfb6e4cb03bc063c74b1096fca5a7cd
By determining what the washer WON'T DO, you should be able to determine (also using the Whirlpool manuals' troubleshooting section) what part you need.
Hi own a Kenmore Type 111, Model 110.25652400, Serial # CS1013360 washing machine
Those parts are very common and cheap to buy. The problem is your model number isn’t correct. Leave out you serial number and re-check the model number. When dog agits go bad, the bottom half of the agitator should still work.
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
1helpful
I would like to know the year of my Kenmore special edition washer and dyer SM 97 10804-4
Hi C,
Looks like around 2001 according to Serial #.
110 prefix means Whirlpool manufactured this item for kenmore
1helpful
Model # 110 20702 991 Serial # CK 5008937 Type 111 Can hear motor running and makes a slight noise also drains but won't engage in washer spin
Hello, Thank You for using FixYa. I will be helping you today.Sounds like a failed motor coupler part number 285753. It connects the motor to the trans. You can lean the unit back to change this part. Remove the pump remove the motor and you will see it.
Thank You and please rate my answer if it was helpful..
I have a Kenmore 90 series dryer.The only number
the door should have a sticker where it closes against with model and serial numbers as for the second part ck terminal connection to elements to make sure they are tight next shoot continuity of the elements limit switches thermal fuse elements will be between 9 and 13 ohms others should read 0
No cold water going into tub, valve is open
make sure the hoses are not kinked and check the screens inside the valve inlet and make sure they are not clogged
31helpful
2answers
What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
2answers
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Alexander
vince
