Question about Apple MacBook Pro Notebook
Repated start up requests from the computer
At start up the screen goes dark gary with these instructions in several languages. You need to restart your computer. Hold down the   Power button foe several seconds or press the restart button. After each restart this same message appears
    Scholar:
  • 186 Answers
That means Hardware Error. It is a gray iron curtain with a black dialog box. Most likely bad Ram/Memory, but If warranty, call Apple. Otherwise there should be a diagnostics CD or DVD that came with your recovery Disks. It should tell you what's wrong if it can boot before the Iron Curtain comes down again.
You can try swapping ram with a recent age mac or pc laptop and see if it repeats.
Posted on Apr 27, 2008
    Problem Solver:
  • 14 Answers
This is what is known as a "kernel panic". <http://tinyurl.com/hcgku> Seeing it repeatedly at startup is not a good thing.
The surest way to cure it is to use the most current version of a MacOS install disc available and do an "Archive and Install" so that the hard drive is not completely erased. (detailed here: <http://tinyurl.com/qcym> )
HTH
Posted on May 06, 2008
    Problem Solver:
  • 6 Answers
Is there a CD in the drive that the Mac could be booting from? The screen you mention sounds like the start up screen on a Mac OS install disc.
Posted on Mar 28, 2008
My asus eee pc will not start windows. I've tried pressing F2 (and the bios screen comes up) F7, F8 and F9 ask me if I want to run system recovery, but when I say yes, it acts like it's about to...
Restart your computer..start tapping F8 quickly..if you reaches advance boot menu..there select repair my computer..then select the language..then enter your username and password if you use any..in recovery options you can try startup repair or system restore options..lastly if nothing works then select the factory image restore which will take your computer to factory settings but delete everything
Aug 24, 2011 | ASUS Eee PC 1001PX (1001PXEU17BK) Netbook
How do I restart my computer?
Hello.
If your computer is on and you want to warm restart, select the 3 keys (Alt-Ctrl- Del) and the computer should restart without powering off.
If you want to cold restart, hold down the power button on your tower for at least 5 seconds and then let go when your screen goes dark. Push the button again to start.
Hope this resolves your problem.
Nov 20, 2010 | Computers & Internet
Frequent curtain of doom stops my PowerBook G4
You need to reset the firmware...
first up, do the 'soft' reset: 1) Boot into the Open Firmware. (Command + Option + O + F)
2) type reset-all followed by the return key
If that doesn't solve the problem, check this out.. http://support.apple.com/kb/TS1417
Is there a firmware update waiting to be downloaded (check in 'software update')
Jul 22, 2010 | Apple PowerBook G4 Mac Notebook
Computer froze and will not restart
Remove the battery, and boot up but holing the power button down until you hear a loud Beeeeeeeeep, and the lights start flashing. Let go, and wait.
Regards.
Jul 21, 2010 | Apple MacBook Pro Notebook
After I turn on my computer,the usual Toshiba display information comes on,but after that,I'm just getting a black screen.Windows does not want to start.It was fine a few hours ago,last time I used...
if you would like to reset to factory default turn off unplug power remove battery wait 30 seconds replace batt & power hold down zero button restart pc do not release zero button until you see screen flashes and you see cursor blinking at top left release follow instructions for restore to out of box state pc will restart several times do not touch until you see choose language page.....this is for windows 7
Apr 07, 2010 | Computers & Internet
Monitor won't stay on
Restart the computer and tap on f8 button so u can start computer in safe mode, if u are able to restore computer to earlier tiem. IF u are unable to start using safe mode. Ur computer need to reformat. Please insert recovery disc restart computer and tab on down arrow button and follow onscreen instruction...
Jan 19, 2009 | Liquid Video E15LCD1 15"
Mac Book Pro repeats Start Up Instructions
what instructions come at startup? please be clear
Mar 21, 2008 | Apple MacBook Pro Notebook
Computer turn-on problem
dot.gif POST troubleshooting steps. Question: Post troubleshooting steps.
Additional information: This document is intended to help users who are experiencing issues with the POST and may have any of the below symptoms.
  1. Computer beeps irregularly when the computer is turned on.
  2. Computer turns on but does not boot.
Note: Not all computers have beep codes, some of the newer computers have LED's that light up that indicate the error or have a sound file to indicate the error.
Cause: This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Answer: Warning: Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards. Information about ESD and proper grounding techniques are found on our ESD help page. Note: Make sure your computer is turning on, if you press the power button and nothing happens (no lights, no sound, no fans, etc.) then this issue is not a NO POST but is an power related issue see document CH000312. Remove new hardware If any new hardware has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device.
Disconnect external devices Remove everything from the back of the computer except the power cable. Turn on the computer and see if it beeps normally. If the computer has never beeped keep the monitor or display connected to see if any change occurs.
Identify beep code If you are receiving a sequence of beeps see our beep code page for a listing of different beep codes and their explanation and/or your motherboard or computer documentation. These beep codes are meant as a method of quickly identifying what computer component is failing or bad.
Check all fans Make sure all fans are running in the computer. If a fan has failed (especially the heat sink fan for the CPU) your computer could be overheating and/or detecting the fan failure causing the computer not to boot.
Check all cables Verify that all the cables are properly connected at that there are no loose cables by firmly pressing in each cable.
  • All disk drives should have a data cable and power cable connected to them.
  • Your power supply should have at least one cable going to the motherboard. Many motherboards may also have additional cables connected to them to supply power to the fans.
Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST attempt to disconnect the Riser board (if applicable) and/or each of the expansion cards. If this resolves the issue or allows the computer to post connect one card at a time until you determine which card is causing the issue.
Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect the IDE, SATA, SCSI, or other data cables from the CD-ROM, hard drive, and floppy drive from the Motherboard.
If this resolves your irregular post or you now get an error message attempt to re-connect each device one at a time to determine which device and or cable is causing the issue. In some situations it can also be simply a loose cable connection that causes the issue.
Remove the RAM If you continue to to receive the same problem with all the above hardware removed attempt to disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue.
  1. Re-insert the memory into the same slot.
  2. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick.
  3. Try one stick of memory in each slot.
If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify which stick of memory is bad and replace it.
If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard.
Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply and/or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot.
This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware.
Disconnect and reconnect the CPU For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer.
Bad motherboard, CPU, RAM, and/or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have bad Motherboard, CPU, and or RAM. The next step would be either to replace these components and/or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order and/or try swappable parts from other computers.
Dec 06, 2007 | Apple MacBook Pro Laptop Computer with...
Apple MacBook Pro Notebook Logo
160 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
