Question about Asko W6441 Front Load Washer
Asko W6441 Washer
My Asko W660 makes a horrible noise when turned on and it can't be stopped unless the power is turned off. I was able to get the fault indicator "Overflow" to come up after turning it on and off a few times. I've checked the trap and it was clear (oh and detached the red plastic pull that you use unlock the door manually and now have a string hanging, but that is another issue...).
The book says to call a Service Technician. I did, but he can't come for 10 days. Is there anything else I can try myself or I'm stuck with a visit to the laundromat?!
Thanks!!
  • javaluvr Mar 23, 2008
    Thanks greendude - this got me on the right track and I was able to fix it!! After I posted I discovered that a block in the house pipes (that's my tech term - ha!) caused the overflow in the washer. I got that fixed and still had the washer problem. I took your advice and tipped the machine back. Lo and behold the horrible noise stopped! I was able to start the machine... but, it wouldn't drain. Based on the "water outlet fault" I checked the trap and found nothing. Then I pulled the machine away from the wall and used my high speed tool (two coat hangers twisted together) to clear the water outlet hose. Nothing big came out... but hey, it works now and feel like superwoman! Thanks again :)
    Sergeant:
  • 351 Answers
Tip machine back to see if water runs out,then see if it runs.but you may have a leak.also remove top panel and see if grey vent hose on rear of soap draw is leaking on drum end if so replace and glue.if water leaks from there it will damage the motor bearings ant the thermistor that sits above the motor.just tie the door release back on.look into the pump with a tourch,you may fin somthing still in there because if it cant drain it will over fill and cause on overflow fault.hope this helps
Posted on Mar 23, 2008
W6441 Error message
google this with the model # and the brand along with the F4 error code
Jul 25, 2015 | Asko W6441 Front Load Washer
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
Asko washing machine w660 "Temperature stop failure"
DOES THIS MODEL WASHER ACTUALLY HEAT THE WATER? OR JUST ALLOWS A CERTAIN AMOUNT OF HOT WATER TO BE RELEASED OR MIXED WITH COLD WATER? U CAN CHECK THE SWITCH WITH A MULTI METER FOR OHMS OR CONTINUITY NO NEED FOR A TECH GUY
Jan 10, 2014 | Asko Washing Machines
Can't download manual for W6441 washer
Here is the link for your manual you requested.
Manual
I hope this helps
Aug 28, 2011 | Asko W6441 Front Load Washer
My Asko W6441 front load washer F3 message
Hello. You said that you checked the drain line for obstructions, but did you check the pump? I would remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Check the pump for any obstructions (like the occasional stray sock) and check the pump impellers. Look for broken/missing blades and ensure that the impeller spins freely. If there are missing/broken blades or if you cannot get the impeller to spin freely, the pump is defective. You may have already done this, and if so I apologize. Anyway, hope this helped and best wishes.
Aug 28, 2009 | Asko W6441 Front Load Washer
Drum does not spin - doesn't wash either.
motor brushes could be worn out or it has a break in the motors wring & will need to be replaced!
Jul 21, 2009 | Asko W6441 Front Load Washer
ERROR F3 - WHAT DO I DO?
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
May 24, 2009 | Asko W6441 Front Load Washer
Asko washing machine has no power
check your ground fault interupters (outlets with butons) under the sink and around the kichen
then check the breakers in your breaker box
finaly call a sertified tecnition
Jan 22, 2009 | Asko W6441 Front Load Washer
ASKO w660 Parts
lick on this link and contact the parts warehouse they will be able to help you. http://www.askousa.com/buy-asko/contact-us/
Jan 16, 2009 | Asko W660
Using asko washer front load
Close the door firmly.  It won't start until the door is sealed shut.
Dec 10, 2007 | Asko W6441 Front Load Washer
Asko W6441 Front Load Washer Logo
370 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
