Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitsubishi WS-65513 Hello, I bought this tv in 2004 and its been a really good tv until now. When turning the tv on it appears as if your looking at the tv through water? After about 20 min. it seems like it warms up and then is fine. Also it just started turning itself off but the green light stays on?  Please any help would be apperciated! Thanks Dan
  • kats9698 Mar 24, 2008
    When I turn the t.v. on, the picture is wavy, like it is not getting a good reception. After 20 minutes or so, the picture clears up and occasionly does the same thing for a few seconds.
    President:
  • 3,130 Answers
I have a fix for that Dan if you are handy and can solder. You will be able to save about 1000 bucks or so at least. Leave an e-mail address and I will send the repair documents for that model of set. Good Luck
Posted on Mar 21, 2008
SOURCE:
Mitsubishi 65513 TV, dm board
I dont have a pdf but I have something that can help your problem.
Just click below for the solution related to your problem of DM board.
http://www.fixya.com/support/t1012464-fixed_blinking_light_but_still_no
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Mitsubishi WS-65513 65" Rear Projection...
GREEN FLASHING LIGHT MITSUBISHI WS-65513
On the front of the tv there is a small hole with a push button in it. Take a toothpick and push the button until the light stops blinking. This should reset your tv.....Joe
Dec 21, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 blinking light
After taking the back off look to the left side of the tv at the bottom and you will se a silver metal box with some small holes in it. The DM board is in this metal box. Good luck
Nov 30, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
How do you changea mitsubishi dlp tv lamp, bulb only?
A ws-65513 is not a dlp and does not have a lamp. Is WS-65513 your model number? If not what is it?
Sep 17, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 green blinking light
Good Day, nixonam;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 08, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi TV WS-65713
Please send me the instructions on how to remove and repair the dm board in my mitsubishi ws-65513 tv. The green light keeps blinking. thanks
[email protected]
May 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS 65513 turns itself off
Probable four bad caps in DM module = 1000mf/25v
Common repair for qualified Mits tech...........T.
Nov 11, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws-65513
Have you looked at the DM board fix yet that's available here. http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Check it out. If the inside of your TV set does not look like this, you will need to get the service manual to disassemble the set and get to the DM board, but use the rest of the guide to repair the board. If you are successful, you will save almost a 1000 bucks! Good Luck
Jul 14, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
