Question about Panasonic NN-C980 Convection/Microwave Oven
Panasonic NN-C980B stopped working. Blown fuse.
Panasonic NN-C980B stopped working. Opened top panel and discovered the 18A special fuse was blown. I replaced the fuse and tried it again, but it blew the fuse again. What are the possible causes?
    Problem Solver:
  • 7 Answers
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Posted on Jun 02, 2010
SOURCE:
My Panasonic NN-S533 1300 Watts,don't work.
HI,
Just visit this link HERE and your whole problem will be solved.
Refer the points 6.17,6.20,6.21,
Goodluck,
Please don't forget to rate the solution
Apr 03, 2008 | Panasonic NN-S561 Microwave Oven
Panasonic NN SD277W
The internal fuse has blown indicating a secondary problem, it may be one of the door switches is defective or a more serious issue.
Jun 02, 2012 | Panasonic NN-H275 Microwave Oven
The Mocrowave Panasonic NN P295 stopped working. Not a single light is on. I checked the power at the receptacle - is OK. May be the fuse inside the microwave was blown. How can I replace the fuse. Where...
Did you recently have trouble with the cooktop lights?
Sometimes when the cooktop lights blow or are inserted or removed while the oven is still plugged in, the filaments can short, causing a surge that damages the controller.
They can be repaired. More details here.
Nov 05, 2011 | Panasonic NN-P295SF Microwave Oven
I opened it from the right side where electric circuit is just behind the front panel, and found a blown 18A fuse, replaced it with same exact fuse and still keep blowing fuses.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
If it is the type with an "Invertor", they are not user serviceable and must be repaired by an authorised Panasonic agent for continued safety, otherwise if conventional;
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Mar 22, 2011 | Panasonic NN-S254BF Microwave Oven
NN-T964SF 1250 Watts Microwave Oven: my microwave went dead and wouldn't turn on at all...
Sounds like a blown fuse. Carefully remove the cover, and the fuse in directly behind the power cord on the top. Radioshack sells 15A ceramic replacements.
May 17, 2010 | Panasonic NN-T964SF Microwave Oven
NO POWER
Most likely have blown a fuse , get behind the touchpad to ohm the fuse out , replace if blown , if continues to blow check componets for shorts , there will likely be signs of burnt parts.
Phil
Apr 14, 2009 | Panasonic NN-S254BF Microwave Oven
Terminal connector to the door switch overheated & fuse blown
Just cleaning is not enought.The terminal is loose and that isusually the problem most of the time.Replace them with new ones and I think you be happy.
Mar 12, 2009 | Panasonic NN-P794SF Microwave Oven
I cannot get my unit to turn on
Service manual can be got here... http://www.free-service-manuals.com/Kitchen_Appliances/Microwave_Ovens/Panasonic/Panasonic_NN-P294_Service_Manual_-_Simplified_L29796
There is a small ceramic 18A fuse located on the circuit board behind touch pad. You have to remove the top and wrap around panel to get at it. Had same problem, my fuse was ok though. My problem seems maybe in dor switches. http://www.fixya.com/support/t610587-nnp_294_dead
Hope yours is just a fuse. Good luck!
Jan 10, 2008 | Panasonic NN-P294WF Microwave Oven
Panasonic NN-C980 Convection/Microwave Oven Logo
766 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
