I can not enable wireless security it will not save my settings on a edimax Ar7024
    Prodigy:
    An expert who has answered 500 questions.
  • 602 Answers
First things first!
hello
1) did you reinstall the OS?
2) what OS you have? VISTA? XP pro?
3) if any other wireless aplication running?
4) download a new version of wireless program for your particular wireless card. IT SHOULD WORK and save settings.
Good Luck
Posted on Mar 28, 2008
Unable to connect internet to wireless router
has the wireless part of your router been enabled?
Suggest you go into the router config and try enabling wireless. Dont forget to set the security/encryption.
Then set the pc or laptop up with the same security settings.
Nov 29, 2008 | Computers & Internet
Trying to connect new printer wirelessly, cannot get past the wpa security key
You may need to verify the wireless security enabled in your router. Check from your router's setup page the security type and security key enabled in it to connect your wireless printer.
Hope this helps!
Nov 13, 2008 | HP Computers & Internet
Can not get security for dlink
You may need to access your router setup page to verify the wireless settings in the router. Using a computer that is wired to the router, open up IE and type 192.168.0.1, that is the default IP address of your router. Then, a window will open asking for a username password. The username by default is admin. Just leave the password field empty.
Once you're in the setup page, click on WIRELESS tab which on the left side of the page. On the Wireless page, you will see the wireless settings set in the router. You may also enable the wireless security on that page if there is not security enabled yet.
Please check this for your reference http://support.dlink.com/Emulators/di524/h_wireless.html
Hope this helps!
Nov 09, 2008 | Computers & Internet
Need a security key or passphrase
Access the setup page of your router using a computer that is wired connected to it. Then go to wireless settings, there you will find the wireless security(security key or passphrase) enabled in your wireless network.
Nov 04, 2008 | Computers & Internet
I've installed my wireless router, modelwrt54g2v1, and the yellow ethernet cable is still connected to my laptop, once I remove it I have no connection?
The yellow cable (CAT5) is giving you your internet connection
you will need to follow some steps:
1) Access the routers GUI (usualy by going to a web-page in your Internet explorer EG 192.168.0.1 check the manual)
2) make sure that wireless is enabled on the router + DHCP is enabled
3) at this stage set wireless security here as well (to stop unwanted use of your broadband and people hacking your PC)
4) make sure that the laptop wireless is switched on, sometimes there is both a physical on/off switch and a software/keyboard enable/disable button, disconnect the Yellow network cable
5) go to control panel:network connections
6) right click on the wireless connections icon and then view available wireless networks
7) if you see your network then highlight it and click connect
8) enter the security password (if any) which you set in step3 above.
let me know how you get on
Aug 29, 2008 | Computers & Internet
I can only connect thru my router when hardline connected. Cannot connect thru wireless. wrt310n router
On the computer wired to the router.
1. Open an internet explorer browser
2. Go to 192.168.1.1
3. Leave the user blank then "admin" for password unless you changed it.
4. Go to the wireless tab Check the wireless settings If the Wireless network name is Linksys change it.
Cilck save settings.
Go to the subtab wireless security.
Change the security to WPA Personal
then for passphrase put in a password 8 chars or more.
Click save settings.
5. On your computer use the wireless connection to connect to your network name then enter your password
If that does not work or if you have difficulty with the directions just call linksys support 8003267114
Aug 18, 2008 | Computers & Internet
How do i enable wep security on my belkin wireless routeron my pc & what do i do for 2 laptops
check
Setting up wireless security
Belkin : Support : Configuring Wireless Security
Enable wireless and wireless security on your Belkin ...
Generally access the router control panel panel putting router ip number on internet explorer bar. You will be asked for passwords. Check IP number and password for your model on manual.
On panel go to wireless then security, you find menus at left and top bar of the router control page in internet explorer.
Set encryption and input the password.
Do save all command (button at bottom of page).
set wep password also on wireless networked computers.
Jul 07, 2008 | Belkin Computers & Internet
I have a wireless router and it works fine, but it is unsecured. How do I set up security ?
Securing wireless is a pretty simple process.
You can access your router by opening a IE browser page, then typing the default gateway IP address on the address line. In my case, my router is a Linksys. The default gateway is 192.168.1.1
Once you type that in, you will get the login prompt for the router. In general, the default user name and password is USERNAME left blank, PASSWORD admin the reverse, or admin for both. If those don't work, check the documentation for your router.
Once you access the router from the browser, you will have an option for Wireless, and in that option to enable security.
Currently, the most popular type of encryption is WPA-TPIK
Select that oprion if available, then select a passphrase. Personally, I suggest an old phone number you recall from your youth, it is 10 digits, and hard to associate with you but easy to remeber. Once you set encryption and the passphrase, save the settings and exit the browser.
When you try to connect to the network again, you'll be prompted for the passphrase, and a confirmation. Once entered twice, then you'll connect and have a secure connection.
Other suggested security items once security is enabled:
1. Change the login and password of the router (Done in the same router setup as the security)
2. Disable the SSID broadcast once the network is configured (Don't advertise the network)
Some web links on wireless security:
http://www.practicallynetworked.com/support/wireless_secure.htm
May 17, 2008 | Computers & Internet
I would like to know how I can make my Linksys pasword protected. i have two laptop computers on my wireless system. Thank you.
Hi kisthene,
To enable the wireless security, pls open a browser at 192.168.1.1, pls enter user name and password, on the next display pls click on the Wireless tab, pls note down the Network Name (SSID), pls click on the Wireless Security tab, select WEP, next display pls choose your Encryption (either 40/64-bit 10 hex or 104/128-bit 26 hex digits), in the Passphrase, pls enter your alphanumeric chosen password (or you can allow the router to auto generate, though easier to forget) you may or may not enter Key 1 ~ 4 and/or TX Key 1 ~ 4, click on Save Settings button at the bottom. The router may ask you to reboot it.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 26, 2008 | Computers & Internet
Wireless Router
If you clicked repair connection at anytime, you need to reset the router, by way of a reset button on the rear or front, go to your wired network card properties in control panel>network connections, click TCP/IP line, click properties again and select obtain ip address automatically. At this point you can run the setup wizard again if you wish using the rj45 cable You should set up the router using an RJ45 lan cable which comes with the unit and get into the routers settings by typing it's ip address in your web browser 192.168.0.1. Check that DHCP is set at enabled to give your pc's an automatic ip address. Check that wireless is also enabled and save any changed settings. Go to the properties of your pc's wireless adapter in control panel network connections and on its TCP/IP line check that obtain ip address automatically is ticked. when you have set up your wireless connection and the router is set up correctly, disconnect the rj45 cable and if neccassary dissable the wired network card so as the router looks for your wireless adapter and gives it an ip address. When a connection is found by your wireless connection you need to go into the router again and set up your wireless security, using whatever method you choose eg WEP or WPA PSK. You need to select the numbers and letters mixture pass phrase that you use for encyption and use the same numbers in the wireless adapter when it asks for the passkey no., you should then be able to connect again securely.
Sep 10, 2007 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
