Malber WD800 - Will not fill
I have a Malber WD800 that I hook up via my kitchen sink. Lately the pump makes a loud buzzing/grinding noise as if it's trying to draw in water but it takes several minutes before the water starts to fill.
Any advice on how to fix this?
  • 1 more comment
  • eblw Apr 01, 2008
    Thanks you very much for the advice. It sounds exactly right. I'm going to keep an eye/ear on the inlet valve and will try switching them once the valve is too far gone. Thanks again!
  • hjolles Oct 16, 2008
    My washer dryer makes a buzzing noise and doesn't fill with water as easily, the water comes in after some time.
    also, now the dryer is running very hot and doesn't seem to drain as easily either.
    Let me know if you tried the solution included in the previous response.
    Thanks,
  • eblw Oct 30, 2008
    I finally replaced the valve over the weekend and the machine is running like new. I don't run the dryer so I don't know if it was causing problems there. Thank you pete5runner for the assist.
My malber sounds like a jet plane lifting off at various points during the cycle, when it's spinning, I am pretty sure.  Any ideas?
Posted on Aug 03, 2009
  • 55 Answers
The thing making noise is probably the inlet valve, not the pump. The pump pumps the used water out the drain hose. Anyway, if the noise happens when water is trying to come in, the inlet valve is probably faulty. Onw way to get around this without repair is this: If you are hooking up to the sink, that means you are using only one hose to the machine. The other inlet to machine is probably capped off. Remove the cap, and the hose to the respective inlets, and reverse. You will probably have to change your water temp selectors on the front of the machine. If this makes it run OK, then you can later buy an inlet valve and replace at your leisure. For parts call 718-767-7396 in NY. I hope they will ship to where you are. Good luck and let me know what happens.
Posted on Mar 21, 2008
  • peter phillips Oct 30, 2008
    I am glad the solution worked. The inlet valves usually don't actually break, but they do get clogged. If they can be taken apart and cleaned, they will probably work like new.
    Peter
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Malber wd800
Water-Melon. Ok? W-A-T-E-R-M-E-L-O-N :D
Sep 09, 2013 | Dryers
My washer fills and agitates, but when it gets to the rinse/spin cycle it stops and makes a loud grinding noise. Thanks for your time
If it doesn't drain the water after the wash cycle and the sound is more like a buzz then the first thing that I suggest you check is the lid switch. If the lid switch is damaged then the machine will not pump the wash cycle water out and it will not go into the subsequent cycles. The "grinding" or buzzing sound can be caused by an intermittent signal reaching relay switches or solenoids.
Feb 03, 2011 | Kenmore Washing Machines
Dishwasher makes a loud noise until I turn on the water in sink
You have too much water pressure it sounds like for the fill valve to operate properly. I am assuming it is chattering? How much water pressure do you have? If its too high an inexpensive regulator can be purchased at most plumbing supply stores to install in the DW supply line.
Jul 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
HOOK UP
Most portable washer come with a adapter for the sink so you can hook the fill and drain to the sink. There are some models that only hook the fill hose to the sink and the drain is a seperet hose you hang into a sink. If the unit is new the adapter should have been included with it. If it was used you can get the part at any hardware store or appliance parts dealer. Good luck
Jul 11, 2007 | Malber P21 Front Load Washer
Leaking from the front top of machine immediately when cycle begins...
Not sure if this is the same problem but my old WD800 used to spew water out of the top left corner where the detergent tray is. This occurred at one point in the cycle. It was cured by turning down the incoming water pressure on the external tap under the kitchen sink (in this particular case, the cold water)
Jan 28, 2007 | Malber WD1000 Front Load Washer/Dryer
My washing machine won't fill with water
I have my washer connected to the kitchen sink. In order for it to fill I have to connect the hose to the faucet and turn it on, it is pain but that is the only way it will work for me. I hope this helps.
Sep 15, 2006 | Malber P21 Front Load Washer
Washing Machines Logo
278 people viewed this question
Top Washing Machines Experts
