Question about Ricoh 6513 Copier
Ricoh 6513 streaking
Hi there, it looks to be streaking oil, is there an easy fix without calling in service? thx scot
Depending on your use IE lots of thick paper 150gsm plus.
The fuser rollers wear very quickly.
There is no Cheap fix for this.
These machines are very costley to run.
Ricoh Tech L3 22 years exp.
Posted on Mar 22, 2008
THE COPIES ARE COMING OUT WITH BLACK STREAKS. LOOKS LIKE SOMETHING COULD DO WITH CLEANING. IS THIS A JOB FOR ME TO JOB OR AN ENGINEER?
This machine uses a single drum and cleaning unit and a transfer belt assy with its own cleaning unit. That being said if one color is steaking they all would streak. My 1st guess without seeing copies from the machine would be that your problem is fuser related look in the fuser especially around the fingers for damage to the roller (this is common on these.
Good Luck
Mar 01, 2010 | Ricoh 6513 Copier
Aficio 6513 ID sensor location / service manual
The ID sensor is located under OPC drum.Clean the optics component,the charge corona ,and see if the OPC drum is good(change every 120000 copies).
Oct 21, 2009 | Ricoh 6513 Copier
My ricoh 6513 leakes lot of developer
u nuts ?? replace the seals or buy a used dv unit
Jun 25, 2009 | Ricoh 6513 Copier
Ricoh 6513, service code 551
SC551 is thermistor pressure roller error. Check for paper jams in the fuser. It could need a new thermistor.
Make sure the fuser is secured and properly seated in the copier.
Jun 12, 2008 | Office Equipment & Supplies
Service code 551
SC551 is an error with the fuser unit. The thermistor could be bad and need to be replaced or the press rollers are worn.
It should be looked at by an experienced technician to get problem repaired.
Jun 12, 2008 | Ricoh 6513 Copier
Ricoh 6513 - no power
There is no schematic available. Only point to point wiring for the various modules. If you have no power at all, nothing starts glows or blinks on the control panel or on any of the various boards then you will need a service call to try to resolve the problem. It may require a board swap to see if that board is at fault. Unfortunately the days of repairing boards are long gone. Sorry!
Dave T
Jun 02, 2008 | Ricoh 6513 Copier
Ricoh 6513 error code PM CAll
Preventive maintenance.....
It's for a clean up, and sometime there's some parts to replace...
Apr 04, 2008 | Ricoh 6513 Copier
Ricoh 6513
A sc541 code is with the fixing ass'y did you try to reset it? Did it come right back? Is the fuser warm to the touch? If so it is most likly to be one or both of the termister in the fuser. If it is cold it may be the fuser heatting lamp or thermal fuse
Feb 08, 2008 | Ricoh 6513 Copier
Ricoh 6513 Copier Logo
71 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
