Zanussi aquacycle 1400 fle 1416w started to make an electric arking noise when spinning now. Now it has stopped spinning. Will the motor be dead or will it just be the carbon bushes that need replacing. Thanks in advance
    Scholar:
  • 74 Answers
Hiya Cheap6... more than likely the brushes.. which are easily checked to see if they are worn down.. otherwise its a new or RE-con motor.
Regards Faggly
Posted on Mar 21, 2008
SOURCE:
Zanussi fle 1416w wont fully drain the water out and final spin leaves clothes quite wet. When i turn the drum manually i can hear the water below the drum sloshing about. What's wrong with it?
Hi.
Check for drain blockage, check position of the drain hose and check the pressure switch.
1) Access the drain filter and look for drain blockage. With Zanussi front loaders this located in front at the bottom right hand corner, there is an access door in there.Open the door, unscrew the cap and use a container to collect the water. Disconnect power before starting maintenance.
2) Check the position of the drain hose. Make sure that the height of the hose elbow is as specified in the manual or you get siphoning (water getting back from drain hose inside the tub) and drain does not end.
3)The machine has a pressure switch. It is a sensor connected to a long thin rubber hose. The pressure switch is located in control assembly. Clean pressure hose and switch. One way to test the pressure switch is by blowing into the switch, but manufacturers say this must not be done as you can damage a good switch.
The pressure switch is difficult to test in full. Testing is done either reading voltages while machine is cycling or reading Ohms at the switch with tub empty and full. For safety reasons I suggest users to avoid performing tests or maintenance that must be done with power on.
Here a page about drain/spin problem.
Start checking drain hose and drain filter.
Regards.
Ginko
Aug 18, 2011 | Zanussi FLE1416W Front Load Washer
I have a Zanussi FLS1183W aquacycle 1050 washing machine. It has stopped spinning and I suspect the carbon brushes. How do I access the motor to examine/replace the brushes?
There is no solid base to this washing machine so if you simply lie the machine on its side you can access the motor from underneath.
Jun 01, 2010 | Zanussi Washing Machines
Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Dec 31, 2009 | Zanussi ZWF1230W Front Load Washer
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
Door light always on/start button flashing- machine not working
i have just fitted a new pump to my Zanussi FLE 1416w washer, the main power light is on but the start button does not light up.
Can you help.
Oct 14, 2009 | Zanussi FLE1416W Front Load Washer
When my zanussi aquacycle 1200xc is on the fast spin cycle the spinning drum seems to be getting noisier of late.
Probably the main bearings are going, spin the drum by hand, there should be little or no noise at all, if it feels rough, or noisy, then bearings are failing.
Please rate my solution.
Thanks.
Oct 10, 2009 | Zanussi F1245W Front Load Washer
Zanussi Aquacycle Washing Machine wont spin?
Assuming its pumping out ok, sounds like motor brushes..if not pump clear filter..
Oct 06, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Mar 20, 2007 | Zanussi F1245W Front Load Washer
Washing Machines Logo
444 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
