Question about Frigidaire GLTF1670A Front Load Washer
Frigidaire Front Loader Won't Drain
I'm actually not 100% on the model. It says Gallery on the front of the dryer and nothing on the washer. We have a front loading stackable washer that's about 5 years old. Today (Good Friday of course) is decided to not begin the spin cycle and drain. It fills, washes and then the water stays put. I opened up the bottom and it sounds like there's power going to the motor that looks to be responsible for draining the water (located in the front right corner). I have no appliance repair knowledge but I'm assuming the motor is shot. Any thoughts?
  • Holly31 Mar 21, 2008
    My washer also just decided not to fully drain and spin clothes dry. I already tried it with very little clothes and then again empty and the motor make the noise like its going to start spinning but only shakes back and forth a bit and then quits. It's like its stuck or something, however I can't see anything that could make it stuck. My machine is a Kenmore front load and is five years old. The funny thing it that it was working fine yesterday for doing washes. What happened?
  • Healey0927 Mar 21, 2008
    I actually went back to step one and look to see if something had jammed it. I opened up where all the hoses conect to the motor and look inside the little motor and found a 2" pin stuck in the fan. I removed it and reconnected the hoses and it's running fine again. Hopefully this is all yours is.
If your washer is digital or with elecronic control board check the the motor control board located at the bottom difiniely you have to call a tech to confirm that. other model like wd5595 and wd 8095 has the same problem and it is the motor control unit that always fails.
Posted on Apr 06, 2008
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
I want to change the door around to match the
Unfortunately, only some model Dryer doors are able to be changed, not the washer doors. You can find out the Model of your dryer and I can let you know if indeed you dryer door swing can be changed or not. The other solution is to stack the set to not have the doors impede loading and unloading if your models have a stacking kit available for them. I hope this helps! Good luck!
Dec 29, 2009 | Frigidaire GLTR1670A Front Load Washer
Door opens on wrong side
I don't think you can on a front loader washer.. on your dryer you can see how they have screw covers for interchanging, but on washer there are none.. sorry.. good luck..
Jan 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
No Manual
Please go into fixya.com and give me a rating,Solution solved ,etc..
Neil
Jul 22, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire GLTF1670A Front Load Washer Logo
278 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
