Question about Kenmore Oasis HE 27082 Top Load Washer
Troubleshooting an F1 to a F32 using the press/hold 3x's process
Iv'e already replaced the board once in 2007. Now I get the same F1 flashing. I tried the press/hold 3x's process, and now get a F32 showing. What does that mean?
ALL OASIS WASHERS NEED A SURGE PROTECTOR. IT IS JUST LIKE A COMPUTER .ANY TIME ELECTRIC GOES ON AND OFF YOU STAND A CHANCE OF LOSING BOARD. SEEMS LIKE SEARS WOULD TELL YOU THIS. MAKE SURE YOU ADD THE SURGE PROTECTOR AFTER CHANGING BOARD OR YOU HAVE WASTED YOUR MONEY
Posted on Apr 01, 2008
SOURCE:
How do I set the time on adrenaline digital watch?
two standard digi watch setting processes
1 press and hold mode button until time start to flash
then use the start button to move between hour , minute sec etc and the reset to adjust the time, when correct time set press hold once more to return to normal time.
2 press hold button one push at a time on the third push the time should start flashing , follow the above processes.
Mar 04, 2015 | Freestyle Adrenaline watch
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
My gateway is stuck in configure 3 of 3 at start up
Turn on your computer. If your computer is already on, then reboot it. You need to see the initial display screen to get into the BIOS. Press the F1 key immediately in one second intervals when you see the initial screen displaying the BIOS provider information. The majority of Gateway computers use the F1 key. If, for some reason this does not work, then use the F2. All of Gateway's desktops use the F1 or F2 keys. this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps.
Jan 22, 2013 | Gateway Computers & Internet
My Sony DSC H1 Camera easily get drains the batteries. I already tried to replace new batteries 3x and when i use it, just take 5 shots and the battery was drained already.
If you are shooting with flash and using alkaline batteries, this certainly could be the case. If you are using lithium batteries or NiMH rechargeable batteries and are not shooting with flash, and are having this problem, then there is likely some internal problem with the camera that is draining the batteries unnecessarily.
In that case, you'd want to take the camera to a repair shop for troubleshooting.
Mar 11, 2011 | Sony Cyber-Shot DSC-H1 Digital Camera
The letter C is flasing in my dash board
The flashing "C" in the Instrument cluster if for the Compass. Here's the bulletine...
Subject: Compass Displays a Steady or Flashing "C" In Place Of Directional Heading
Models: 2008 Saturn VUE built on or after 11/09/2007
This PI was superseded to update Recommendation/Instructions. Please discard PIT4699.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern: The compass displays a steady or flashing "C" in place of directional heading.
To return to a normal heading display, press and hold the cluster stem for approximately 2 Seconds.
The displayed heading is not correct after driving for 30 seconds, use the following "Compass Calibration" routine.
Press cluster stem until the Season Odometer is displayed (Not Trip A or B).
Press and hold cluster Stem until the solid "C" is displayed. To the right of the "C" will be the "Zone". Refer to the variation zone map above for the correct setting. Turn the stem Right to increase, Left to decrease. It will take a few seconds for a change of zone to be updated in the display.
Once the Zone is correct, press the Stem to display the Flashing "C". Do not touch the Stem again until the direction is learned. Drive the vehicle in slow circles in an open area until you see a compass (oc tant) heading replace the flashing C.
Note: Vehicles built prior to 11/09/2007 were not built with a compass.
Recommendation/Instructions:
Engineering is aware of this condition and is in the process of root causing. It is known that the Remote Compass Module (RCM), Body Control Module (BCM) and Cluster hardware are not at fault, and these parts should not be replaced.
Reinforce with the PDI technicians that the Compass Zone and calibration is still required as part of PDI.
Hope helps (remember to rate and comment this answer).
Mar 07, 2011 | 2008 Saturn VUE
My acer Linux aspire 1 net book will not let me bring up the internet , when i press browser it say that fire fox is already running and that i will need to close it down and restated but i have tried...
Nothing is on the desktop but the firefox process is in the background. you can navigate to the process manager program or do the following:
-hold alt+ctrl and press F1
(this will take you to a terminal)
-log in with your user name and password (root user is better but I will use a root command in a moment just in case)
-once logged in type what is in these prackets {sudo ps -A} (this will prompt you for the root password if you are not root yet)
-The command "ps" shows all running programs. You will see a list with a PID and a program name.
-type the command in these brackets {kill [PID]} but fill in my PID with your firefox PID
You may have a few running that you have to kill but once you are done -hold alt+ctrl and press F7 and you will go back to graphical mode and Firefox will work.
Have fun
Joe
Jan 16, 2011 | Acer Aspire One Netbook 8.9" Notebook
How to reset to factory settings a toshiba satellite A305-S6829 with Vista ? (pressing 0, or F8 didn't bring me far!
To access the Toshiba recovery partition, power off the laptop. Hold down the 0 (zero) key and turn the laptop on. Keep holding down the zero key until the TOSHIBA logo appears, where you should start tapping the zero key repeatedly. Stop if the unit beeps or when the TOSHIBA logo disappears. The screen should flash ** HDD RECOVERY MODE ** for a split second, then load the Toshiba recovery program right from the hard drive.
Note that this erases all data, and reloads all factory default software. Be sure to back up all your important personal data beforehand!
Dec 31, 2010 | Toshiba Computers & Internet
Kenmore Elite Oasis HE/ Error Code F1
f-1 error code,, replace main contol board ,,pressure swtich is loacted inside board would not fill drain and spin once replaced there will be no more problems, if machine is 2 yrs should be covered under warranty
Nov 24, 2008 | Kenmore Elite HE4 Electric Dryer
HE Elite Smartwash quiet pac 4 front load washing machine
F32 is the pressure switch issue. Just press and hold the power switch for 5 seconds to reset this error.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Aquos LC37D40U Blinking light and won't turn on
The power light is an error code that tells me exactly what is wrong with the TV. Count how many times the POWER led flashes per second? (Dont worry about the OPC led)
1x per second (constant steady blink) = bad inverters/lamps
2x per second = bad power supply
3x per second = bad main board
If its 1x per second, try doing the factory initialization to get the TV back on to confirm a bad lamp/inverter.
Try doing the Factory Initialization (WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go.
Once the TV turns on, take a look at the screen. Does it flicker then shut off? Or do you hear a buzzing noise from the right edge of the TV? If so, then you have bad inverters or lamps. Once youre done, unplug the tv to get it out of the service menu.
If it is 2x per second or 3x per second, then those boards are just bad and they need to be replaced. There isnt anything you can do right now to fix it.
Mar 27, 2008 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Kenmore Oasis HE 27082 Top Load Washer Logo
221 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
